Einleitung
In this guide, you will learn how to disassemble the broken/damaged screen from the rest of the laptop, allowing you to replace it for a new one. This guide will also teach you what the proper and necessary tools are for this repair.
Was du brauchst
With a plastic opening tool, prop the plastic panel up to separate it from the rest of the laptop.
Slowly pull the plastic panel from the entire laptop.
Remove the four 5 mm screws with a Phillips #1 screwdriver, each located at the four corners of the screen.
At this point, the screen should be completely disconnected from the rest of the laptop.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Ein Kommentar
Be careful with this procedure, as there are at least 2 different part numbers for the M400, LTD121KM7K has a 32 pin connector, and a different one, LTD121KC6K has a shorter connector for the display which is not compatible. When ordering from Ebay they do not distinguish between them. I would also like a procedure for replacing the complete screen and lid assembly. I can't find it on the net at the moment. Also, be aware that there may be compatibility issues there too.
