Zum Hauptinhalt wechseln
Toshiba Satellite A205-S4577 USB 3.0 ports Replacement
Was du brauchst
  1. Toshiba Satellite A205-S4577 USB 3.0 ports Replacement, Battery: Schritt 1, Bild 1 von 1
    • Locate the two sliding locks indicated in the photo.
    • Slide the right lock (labeled "1") to the right. It will remain in the unlocked position.
    • Slide the left lock (labeled "2") to the left and hold it in place.
  2. Toshiba Satellite A205-S4577 USB 3.0 ports Replacement: Schritt 2, Bild 1 von 1
    • While holding the left lock, place your finger in the indentation next to the battery and lift the battery out.
  3. Toshiba Satellite A205-S4577 USB 3.0 ports Replacement, Speaker Cover: Schritt 3, Bild 1 von 3 Toshiba Satellite A205-S4577 USB 3.0 ports Replacement, Speaker Cover: Schritt 3, Bild 2 von 3 Toshiba Satellite A205-S4577 USB 3.0 ports Replacement, Speaker Cover: Schritt 3, Bild 3 von 3
    • Remove the four screws indicated in the photos using a Phillips 00 Screwdriver. Left to right: 6mm button-head, 3mm flat-head, 6mm button-head, 6mm button-head.
  4. Toshiba Satellite A205-S4577 USB 3.0 ports Replacement: Schritt 4, Bild 1 von 1
    • With your hands, grasp the speaker cover on the edge nearest to the screen.
    • Pry the speaker cover upward.
  5. Toshiba Satellite A205-S4577 USB 3.0 ports Replacement: Schritt 5, Bild 1 von 1
    • Remove the speaker cover. Your laptop will look like this photo when the speaker cover has been removed.
  6. Toshiba Satellite A205-S4577 USB 3.0 ports Replacement, Front Cover: Schritt 6, Bild 1 von 1
    • Locate the screws that are shown in the image.
    • Remove the fourteen 6mm button-head screws with a Phillips 00 Screwdriver.
  7. Toshiba Satellite A205-S4577 USB 3.0 ports Replacement: Schritt 7, Bild 1 von 2 Toshiba Satellite A205-S4577 USB 3.0 ports Replacement: Schritt 7, Bild 2 von 2
    • Lift up on the front cover to remove it.
  8. Toshiba Satellite A205-S4577 USB 3.0 ports Replacement, USB 2.0 Ports: Schritt 8, Bild 1 von 1
    • Locate the USB 2.0 cable on the bottom right corner of the laptop.
  9. Toshiba Satellite A205-S4577 USB 3.0 ports Replacement: Schritt 9, Bild 1 von 2 Toshiba Satellite A205-S4577 USB 3.0 ports Replacement: Schritt 9, Bild 2 von 2
    • Locate the white slot on the left side of the USB 2.0 wire.
    • Carefully detach the wire by pulling the cable to the right of the slot.
Abschluss
Curtis
103 Reputation
1 Anleitung geschrieben
Cal Poly, Team 17-6, Regan Spring 2013 Mitglied von Cal Poly, Team 17-6, Regan Spring 2013
CPSU-REGAN-S13S17G6
5 Mitglieder
33 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 11
Letzte 30 Tage: 22
Insgesamt: 1,764
