Zum Hauptinhalt wechseln
Toshiba Satellite L305-S5946 RAM Replacement
Was du brauchst
  1. Toshiba Satellite L305-S5946 RAM Replacement, Battery: Schritt 1, Bild 1 von 1
    • Place the laptop upside-down with the display hinges facing away from you.
  2. Toshiba Satellite L305-S5946 RAM Replacement: Schritt 2, Bild 1 von 1
    • Slide the latch for the left battery bay to the left.
  3. Toshiba Satellite L305-S5946 RAM Replacement: Schritt 3, Bild 1 von 3 Toshiba Satellite L305-S5946 RAM Replacement: Schritt 3, Bild 2 von 3 Toshiba Satellite L305-S5946 RAM Replacement: Schritt 3, Bild 3 von 3
    • Slide the latch for the right battery bay to the right and hold.
    • Continue to hold the latch while using a plastic opening tool to lift and remove the battery bay cover.
    • Remove the battery.
  4. Toshiba Satellite L305-S5946 RAM Replacement, RAM: Schritt 4, Bild 1 von 1
    • Using a Phillips #1 screwdriver, turn the screw on the RAM cover until you hear a click.
    • This is a captive panel screw and remains with the cover.
  5. Toshiba Satellite L305-S5946 RAM Replacement: Schritt 5, Bild 1 von 2 Toshiba Satellite L305-S5946 RAM Replacement: Schritt 5, Bild 2 von 2
    • Remove the RAM cover by inserting the plastic opening tool into the indent and lifting.
  6. Toshiba Satellite L305-S5946 RAM Replacement: Schritt 6, Bild 1 von 2 Toshiba Satellite L305-S5946 RAM Replacement: Schritt 6, Bild 2 von 2
    • Push the white and silver retaining clips away from each side of the RAM card using your fingernails.
    • The RAM card should pop up at an angle.
  7. Toshiba Satellite L305-S5946 RAM Replacement: Schritt 7, Bild 1 von 2 Toshiba Satellite L305-S5946 RAM Replacement: Schritt 7, Bild 2 von 2
    • Pull the RAM card away from the computer.
    • Repeat Steps 6 and 7 to remove the other RAM card that may be installed.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Cal Poly, Team 3-49, Amido Spring 2013 Mitglied von Cal Poly, Team 3-49, Amido Spring 2013
CPSU-AMIDO-S13S3G49
4 Mitglieder
19 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 17
Insgesamt: 836
