Zum Hauptinhalt wechseln
Toshiba Satellite L305-S5946 Motherboard Replacement
Was du brauchst
  1. Toshiba Satellite L305-S5946 Motherboard Replacement, Battery: Schritt 1, Bild 1 von 1
    • Place the laptop upside-down with the display hinges facing away from you.
  2. Toshiba Satellite L305-S5946 Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Slide the latch for the left battery bay to the left.
  3. Toshiba Satellite L305-S5946 Motherboard Replacement: Schritt 3, Bild 1 von 3 Toshiba Satellite L305-S5946 Motherboard Replacement: Schritt 3, Bild 2 von 3 Toshiba Satellite L305-S5946 Motherboard Replacement: Schritt 3, Bild 3 von 3
    • Slide the latch for the right battery bay to the right and hold.
    • Continue to hold the latch while using a plastic opening tool to lift and remove the battery bay cover.
    • Remove the battery.
  4. Toshiba Satellite L305-S5946 Motherboard Replacement, Hard Drive: Schritt 4, Bild 1 von 1
    • Loosen the two captive screws on the bottom left corner of the hard drive using a Phillips #1 screwdriver until you hear a click.
  5. Toshiba Satellite L305-S5946 Motherboard Replacement: Schritt 5, Bild 1 von 2 Toshiba Satellite L305-S5946 Motherboard Replacement: Schritt 5, Bild 2 von 2
    • Lift the hard drive cover using a non-marring iFixit opening tool.
    • This will expose the hard drive.
  6. Toshiba Satellite L305-S5946 Motherboard Replacement: Schritt 6, Bild 1 von 3 Toshiba Satellite L305-S5946 Motherboard Replacement: Schritt 6, Bild 2 von 3 Toshiba Satellite L305-S5946 Motherboard Replacement: Schritt 6, Bild 3 von 3
    • Slide the hard drive to the left using your fingers.
    • Remove the hard drive by inserting an iFixit opening tool under the right side of the hard drive and carefully lifting it out.
  7. Toshiba Satellite L305-S5946 Motherboard Replacement, RAM: Schritt 7, Bild 1 von 1
    • Using a Phillips #1 screwdriver, turn the screw on the RAM cover until you hear a click.
    • This is a captive panel screw and remains with the cover.
  8. Toshiba Satellite L305-S5946 Motherboard Replacement: Schritt 8, Bild 1 von 2 Toshiba Satellite L305-S5946 Motherboard Replacement: Schritt 8, Bild 2 von 2
    • Remove the RAM cover by inserting the plastic opening tool into the indent and lifting.
  9. Toshiba Satellite L305-S5946 Motherboard Replacement: Schritt 9, Bild 1 von 2 Toshiba Satellite L305-S5946 Motherboard Replacement: Schritt 9, Bild 2 von 2
    • Push the white and silver retaining clips away from each side of the RAM card using your fingernails.
    • The RAM card should pop up at an angle.
  10. Toshiba Satellite L305-S5946 Motherboard Replacement: Schritt 10, Bild 1 von 2 Toshiba Satellite L305-S5946 Motherboard Replacement: Schritt 10, Bild 2 von 2
    • Pull the RAM card away from the computer.
    • Repeat Steps 6 and 7 to remove the other RAM card that may be installed.
  11. Toshiba Satellite L305-S5946 Motherboard Replacement, Keyboard: Schritt 11, Bild 1 von 1
    • Place the laptop right-side-up so the screen faces you.
  12. Toshiba Satellite L305-S5946 Motherboard Replacement: Schritt 12, Bild 1 von 3 Toshiba Satellite L305-S5946 Motherboard Replacement: Schritt 12, Bild 2 von 3 Toshiba Satellite L305-S5946 Motherboard Replacement: Schritt 12, Bild 3 von 3
    • Remove the strip of plastic at the right furthermost edge of the keyboard using a plastic opening tool.
    • Insert the plastic opening tool at either end of the strip.
    • Lift upwards and proceed to the other end while repeating this lifting process every one to two inches.
  13. Toshiba Satellite L305-S5946 Motherboard Replacement: Schritt 13, Bild 1 von 1
    • CAUTION: do not allow hardware or debris into the CPU fan and duct.
    • Remove the two 3-mm screws at the top edge of the keyboard using a Phillips #00 screwdriver.
    • These are not captive panel screws and, once loosened, will be free to move about the assembly.
  14. Toshiba Satellite L305-S5946 Motherboard Replacement: Schritt 14, Bild 1 von 2 Toshiba Satellite L305-S5946 Motherboard Replacement: Schritt 14, Bild 2 von 2
    • Pry the top of the keyboard loose from its casing using a plastic opening tool.
  15. Toshiba Satellite L305-S5946 Motherboard Replacement: Schritt 15, Bild 1 von 1
    • Gently grasp the top of the keyboard and pull it up and toward the screen.
    • CAUTION: Pulling too hard could damage the black ribbon cable under the keyboard.
  16. Toshiba Satellite L305-S5946 Motherboard Replacement: Schritt 16, Bild 1 von 3 Toshiba Satellite L305-S5946 Motherboard Replacement: Schritt 16, Bild 2 von 3 Toshiba Satellite L305-S5946 Motherboard Replacement: Schritt 16, Bild 3 von 3
    • Gently push the two tabs locking the black ribbon cable.
    • To remove the black ribbon cable from the motherboard, slide the keyboard toward the screen.
    • You may now safely separate the keyboard from the laptop.
  17. Toshiba Satellite L305-S5946 Motherboard Replacement, Base Housing: Schritt 17, Bild 1 von 1
  18. Toshiba Satellite L305-S5946 Motherboard Replacement: Schritt 18, Bild 1 von 1
    • For the following steps, use a Phillips #1 screwdriver.
    • Remove the twelve 6-mm screws that border the bottom of the laptop.
    • Remove the 6-mm screw located in the lower middle of the device.
    • Remove the three 3-mm screws located in the battery bay.
    • Remove the one 4-mm screw located near the RAM.
  19. Toshiba Satellite L305-S5946 Motherboard Replacement: Schritt 19, Bild 1 von 1
  20. Toshiba Satellite L305-S5946 Motherboard Replacement: Schritt 20, Bild 1 von 1
    • Use a Phillips #1 screwdriver to remove the five 6-mm screws in the keyboard slot.
  21. Toshiba Satellite L305-S5946 Motherboard Replacement: Schritt 21, Bild 1 von 3 Toshiba Satellite L305-S5946 Motherboard Replacement: Schritt 21, Bild 2 von 3 Toshiba Satellite L305-S5946 Motherboard Replacement: Schritt 21, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Lock the white ribbon cable into place by gently pulling on the two black tabs.
    • Remove the white ribbon cable by pulling it towards you.
    • Remove the connector that has the blue, red, black, and white wires using tweezers.
  22. Toshiba Satellite L305-S5946 Motherboard Replacement: Schritt 22, Bild 1 von 3 Toshiba Satellite L305-S5946 Motherboard Replacement: Schritt 22, Bild 2 von 3 Toshiba Satellite L305-S5946 Motherboard Replacement: Schritt 22, Bild 3 von 3
    • Separate the laptop upper casing from the lower casing by using an opening tool around the sides of the case to pry it apart.
  23. Toshiba Satellite L305-S5946 Motherboard Replacement, Motherboard: Schritt 23, Bild 1 von 1
    • Remove the four 6-mm screws from the two hinge pads using a Phillips #1 screwdriver.
  24. Toshiba Satellite L305-S5946 Motherboard Replacement: Schritt 24, Bild 1 von 3 Toshiba Satellite L305-S5946 Motherboard Replacement: Schritt 24, Bild 2 von 3 Toshiba Satellite L305-S5946 Motherboard Replacement: Schritt 24, Bild 3 von 3
    Kaufen
    • For the following steps, use tweezers:
    • Remove the connector equipped with the black and white wire.
    • Remove the connector equipped with the black, green, red, yellow, and white wires.
    • Using your fingers, remove the large connector located at the top right corner of the motherboard, as shown.
  25. Toshiba Satellite L305-S5946 Motherboard Replacement: Schritt 25, Bild 1 von 2 Toshiba Satellite L305-S5946 Motherboard Replacement: Schritt 25, Bild 2 von 2
    • Remove the two 3-mm screws from the card equipped with black and white wires by using a Phillips #00 or Phillips #1 screwdriver.
    • These are not captive panel screws and once loosened will be free to move about the assembly.
    • Gently remove the card with your fingers.
  26. Toshiba Satellite L305-S5946 Motherboard Replacement: Schritt 26, Bild 1 von 1
    • Remove the display assembly and put it aside.
  27. Toshiba Satellite L305-S5946 Motherboard Replacement: Schritt 27, Bild 1 von 3 Toshiba Satellite L305-S5946 Motherboard Replacement: Schritt 27, Bild 2 von 3 Toshiba Satellite L305-S5946 Motherboard Replacement: Schritt 27, Bild 3 von 3
    • Slide the DVD out of the opening on the right using your fingers.
  28. Toshiba Satellite L305-S5946 Motherboard Replacement: Schritt 28, Bild 1 von 3 Toshiba Satellite L305-S5946 Motherboard Replacement: Schritt 28, Bild 2 von 3 Toshiba Satellite L305-S5946 Motherboard Replacement: Schritt 28, Bild 3 von 3
    • Remove the power jack connector.
    • Remove the connector equipped with one red wire and one black wire.
    • This connector may be hidden beneath a cooling fan wire.
    • Remove the connector equipped with red, yellow, green, white, and black wires.
    • Remove the large connector near the fan.
    • Remove the power jack cable and socket from its housing by pulling gently.
  29. Toshiba Satellite L305-S5946 Motherboard Replacement: Schritt 29, Bild 1 von 3 Toshiba Satellite L305-S5946 Motherboard Replacement: Schritt 29, Bild 2 von 3 Toshiba Satellite L305-S5946 Motherboard Replacement: Schritt 29, Bild 3 von 3
    • Gently push the two black tabs until they stop moving.
    • Remove the silver ribbon cable from the connectors by pulling gently.
  30. Toshiba Satellite L305-S5946 Motherboard Replacement: Schritt 30, Bild 1 von 1
    • Rremove the 6-mm screw near the hard drive using a Phillips #1 screwdriver.
    • This is not a captive screw and, once loosened, will be free to move about the assembly.
  31. Toshiba Satellite L305-S5946 Motherboard Replacement: Schritt 31, Bild 1 von 3 Toshiba Satellite L305-S5946 Motherboard Replacement: Schritt 31, Bild 2 von 3 Toshiba Satellite L305-S5946 Motherboard Replacement: Schritt 31, Bild 3 von 3
    • Remove the two 3-mm screws from the card connected to the black wire using a Phillips #00 screwdriver.
    • These are not captive screws and, once loosened, will be free to move about the assembly.
  32. Toshiba Satellite L305-S5946 Motherboard Replacement: Schritt 32, Bild 1 von 3 Toshiba Satellite L305-S5946 Motherboard Replacement: Schritt 32, Bild 2 von 3 Toshiba Satellite L305-S5946 Motherboard Replacement: Schritt 32, Bild 3 von 3
    • Gently lift the top right side of the motherboard. Pull it upwards to the right and away from you.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Cal Poly, Team 3-49, Amido Spring 2013 Mitglied von Cal Poly, Team 3-49, Amido Spring 2013
CPSU-AMIDO-S13S3G49
4 Mitglieder
19 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 11
Letzte 30 Tage: 40
Insgesamt: 5,687
