Zum Hauptinhalt wechseln
Audiovox CR8030iE5 Top-Casing Replacement
Was du brauchst
  1. Audiovox CR8030iE5 Top-Casing Replacement, Top-Casing: Schritt 1, Bild 1 von 1
    • Turn the device upside down.
    • Apply constant pressure to the base of your Audiovox, while holding the plastic casing until the casing is completely removed.
  2. Audiovox CR8030iE5 Top-Casing Replacement: Schritt 2, Bild 1 von 1
    • Remove the four screws from the base using a Phillips #1 screwdriver.
  3. Audiovox CR8030iE5 Top-Casing Replacement: Schritt 3, Bild 1 von 1
    • Turn the device right-side up.
    • Gently pull the top panel off of the device.
  4. Audiovox CR8030iE5 Top-Casing Replacement: Schritt 4, Bild 1 von 1
    • Using a Phillips #1 screwdriver, remove the screw found in the middle of the board.
  5. Audiovox CR8030iE5 Top-Casing Replacement: Schritt 5, Bild 1 von 1
    • Pull back the board gently to avoid disconnecting the attached wires.
    • This allows you to view the soldered connections on the other side, and the internal components.
Abschluss
Cal Poly, Team 10-39, Amido Spring 2013 Mitglied von Cal Poly, Team 10-39, Amido Spring 2013
CPSU-AMIDO-S13S10G39
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 12
Insgesamt: 332
