Zum Hauptinhalt wechseln
Toshiba Satellite A105-S4284 Disc Drive Replacement
Was du brauchst
  1. Toshiba Satellite A105-S4284 Disc Drive Replacement, Battery: Schritt 1, Bild 1 von 2 Toshiba Satellite A105-S4284 Disc Drive Replacement, Battery: Schritt 1, Bild 2 von 2
    • Make sure your computer is turned off and the computer is not plugged in.
    • Turn your laptop upside down, and slide the right release tab outward.
    • Using you left hand, hold the left release tab towards the left side and then pull the battery out.
  2. Toshiba Satellite A105-S4284 Disc Drive Replacement, Disc Drive: Schritt 2, Bild 1 von 2 Toshiba Satellite A105-S4284 Disc Drive Replacement, Disc Drive: Schritt 2, Bild 2 von 2
    • Loosen the screw located on the cover of the RAM using Phillips #1 screwdriver.
    • You will not be able to remove the screw from the panel as it is designed to stay in the panel.
  3. Toshiba Satellite A105-S4284 Disc Drive Replacement: Schritt 3, Bild 1 von 2 Toshiba Satellite A105-S4284 Disc Drive Replacement: Schritt 3, Bild 2 von 2
    • With your fingers, carefully remove the middle panel by lifting the edge with the indent.
  4. Toshiba Satellite A105-S4284 Disc Drive Replacement: Schritt 4, Bild 1 von 2 Toshiba Satellite A105-S4284 Disc Drive Replacement: Schritt 4, Bild 2 von 2
    • Remove the 4.0 mm screw above the small metal tab with a Phillips 00 screwdriver.
  5. Toshiba Satellite A105-S4284 Disc Drive Replacement: Schritt 5, Bild 1 von 2 Toshiba Satellite A105-S4284 Disc Drive Replacement: Schritt 5, Bild 2 von 2
    • Push down on the metal tab under the cover with the plastic opening tool and push the disc drive partially out.
    • Grab the drive and pull it out of the laptop.
Abschluss
pfedigan
11 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 2-23, Maness Spring 2013 Mitglied von Cal Poly, Team 2-23, Maness Spring 2013
CPSU-MANESS-S13S2G23
4 Mitglieder
13 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 13
Insgesamt: 846
