Zum Hauptinhalt wechseln
Toshiba Satellite L305-S5946 Hard Drive Replacement
Was du brauchst
  1. Toshiba Satellite L305-S5946 Hard Drive Replacement, Battery: Schritt 1, Bild 1 von 1
    • Place the laptop upside-down with the display hinges facing away from you.
  2. Toshiba Satellite L305-S5946 Hard Drive Replacement: Schritt 2, Bild 1 von 1
    • Slide the latch for the left battery bay to the left.
  3. Toshiba Satellite L305-S5946 Hard Drive Replacement: Schritt 3, Bild 1 von 3 Toshiba Satellite L305-S5946 Hard Drive Replacement: Schritt 3, Bild 2 von 3 Toshiba Satellite L305-S5946 Hard Drive Replacement: Schritt 3, Bild 3 von 3
    • Slide the latch for the right battery bay to the right and hold.
    • Continue to hold the latch while using a plastic opening tool to lift and remove the battery bay cover.
    • Remove the battery.
  4. Toshiba Satellite L305-S5946 Hard Drive Replacement, Hard Drive: Schritt 4, Bild 1 von 1
    • Loosen the two captive screws on the bottom left corner of the hard drive using a Phillips #1 screwdriver until you hear a click.
  5. Toshiba Satellite L305-S5946 Hard Drive Replacement: Schritt 5, Bild 1 von 2 Toshiba Satellite L305-S5946 Hard Drive Replacement: Schritt 5, Bild 2 von 2
    • Lift the hard drive cover using a non-marring iFixit opening tool.
    • This will expose the hard drive.
  6. Toshiba Satellite L305-S5946 Hard Drive Replacement: Schritt 6, Bild 1 von 3 Toshiba Satellite L305-S5946 Hard Drive Replacement: Schritt 6, Bild 2 von 3 Toshiba Satellite L305-S5946 Hard Drive Replacement: Schritt 6, Bild 3 von 3
    • Slide the hard drive to the left using your fingers.
    • Remove the hard drive by inserting an iFixit opening tool under the right side of the hard drive and carefully lifting it out.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Alec
346 Reputation
1 Anleitung geschrieben
Cal Poly, Team 3-49, Amido Spring 2013 Mitglied von Cal Poly, Team 3-49, Amido Spring 2013
CPSU-AMIDO-S13S3G49
4 Mitglieder
19 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 5
Insgesamt: 2,092
