Zum Hauptinhalt wechseln
Sony Clie PEG-NR70 Battery Pack Replacement
Was du brauchst
  1. Sony Clie PEG-NR70 Battery Pack Replacement, The Case: Schritt 1, Bild 1 von 1
    • Unscrew the 1.9mm screw located at the top of the device with a Phillips #00 screwdriver.
    • It may be helpful to set up a piece of paper to keep track of where removed screws came from.
  2. Sony Clie PEG-NR70 Battery Pack Replacement: Schritt 2, Bild 1 von 1
    • Unscrew the 2.5mm screw located on the left side of the device with a Phillips #00 screwdriver.
  3. Sony Clie PEG-NR70 Battery Pack Replacement: Schritt 3, Bild 1 von 2 Sony Clie PEG-NR70 Battery Pack Replacement: Schritt 3, Bild 2 von 2
    • Unscrew the five 2.5mm screws on the back panel with a Phillips #00 screwdriver.
    • Remove the back panel by lifting it away with your hands.
  4. Sony Clie PEG-NR70 Battery Pack Replacement, Battery Pack: Schritt 4, Bild 1 von 2 Sony Clie PEG-NR70 Battery Pack Replacement, Battery Pack: Schritt 4, Bild 2 von 2
    • Pull up on the black tab on the battery pack to reveal the power cord.
  5. Sony Clie PEG-NR70 Battery Pack Replacement: Schritt 5, Bild 1 von 1
    • Disconnect the battery pack from the motherboard by unplugging the power cables. Gently pull the wire toward the bottom of the device.
    • Be careful to not tear the cables! They are very thin.
  6. Sony Clie PEG-NR70 Battery Pack Replacement: Schritt 6, Bild 1 von 1
    • Gently peel back the adhesive to completely disconnect the battery pack from device.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Courtney
49 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 14-11, Maness Spring 2013 Mitglied von Cal Poly, Team 14-11, Maness Spring 2013
CPSU-MANESS-S13S14G11
5 Mitglieder
8 Anleitungen geschrieben
Ein Kommentar
Hi, this is really helpful, thank you.
Richard Hancock - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 18
Insgesamt: 2,140
