Zum Hauptinhalt wechseln
Sony Clie PEG-NR70 Motherboard Replacement
Was du brauchst
  1. Sony Clie PEG-NR70 Motherboard Replacement, The Case: Schritt 1, Bild 1 von 1
    • Unscrew the 1.9mm screw located at the top of the device with a Phillips #00 screwdriver.
    • It may be helpful to set up a piece of paper to keep track of where removed screws came from.
  2. Sony Clie PEG-NR70 Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Unscrew the 2.5mm screw located on the left side of the device with a Phillips #00 screwdriver.
  3. Sony Clie PEG-NR70 Motherboard Replacement: Schritt 3, Bild 1 von 2 Sony Clie PEG-NR70 Motherboard Replacement: Schritt 3, Bild 2 von 2
    • Unscrew the five 2.5mm screws on the back panel with a Phillips #00 screwdriver.
    • Remove the back panel by lifting it away with your hands.
  4. Sony Clie PEG-NR70 Motherboard Replacement, Battery Pack: Schritt 4, Bild 1 von 2 Sony Clie PEG-NR70 Motherboard Replacement, Battery Pack: Schritt 4, Bild 2 von 2
    • Pull up on the black tab on the battery pack to reveal the power cord.
  5. Sony Clie PEG-NR70 Motherboard Replacement: Schritt 5, Bild 1 von 1
    • Disconnect the battery pack from the motherboard by unplugging the power cables. Gently pull the wire toward the bottom of the device.
    • Be careful to not tear the cables! They are very thin.
  6. Sony Clie PEG-NR70 Motherboard Replacement: Schritt 6, Bild 1 von 1
    • Gently peel back the adhesive to completely disconnect the battery pack from device.
  7. Sony Clie PEG-NR70 Motherboard Replacement, Memory Module: Schritt 7, Bild 1 von 1
    • Holding the memory module in place, unscrew the three 0.9mm screws with a Phillips #00 screwdriver.
  8. Sony Clie PEG-NR70 Motherboard Replacement: Schritt 8, Bild 1 von 1
    • Lightly grab the memory module and pull it upwards.
    • Make sure you grab the end closest to the edge of the device. You may have to wiggle the module a bit to get it to come free.
  9. Sony Clie PEG-NR70 Motherboard Replacement, Audio Module: Schritt 9, Bild 1 von 1
    • Unscrew the 2.5mm screw on the top portion of the audio module with a Phillips #00 screwdriver.
  10. Sony Clie PEG-NR70 Motherboard Replacement: Schritt 10, Bild 1 von 1
    • Remove the tape that is holding the module down.
  11. Sony Clie PEG-NR70 Motherboard Replacement: Schritt 11, Bild 1 von 1
    • Lift up the orange ribbon cable and unscrew the two 2.5mm screws located at the corners of the audio module with a Phillips #00 screwdriver.
  12. Sony Clie PEG-NR70 Motherboard Replacement: Schritt 12, Bild 1 von 1
    • Unplug the audio module from the motherboard by disconnecting the wires by lifting the orange wire up.
  13. Sony Clie PEG-NR70 Motherboard Replacement, Speaker Rail: Schritt 13, Bild 1 von 2 Sony Clie PEG-NR70 Motherboard Replacement, Speaker Rail: Schritt 13, Bild 2 von 2
    • Use tweezers to unplug the speaker wire from the motherboard by pulling the plug (not the wires) down towards the speaker.
    • Be careful not to tear the speaker wires! They are very thin.
    • Remove the tape holding speaker wire by peeling it away.
  14. Sony Clie PEG-NR70 Motherboard Replacement: Schritt 14, Bild 1 von 1
    • Holding down the speaker rail unscrew the two 2.5mm screws with a Phillips #00 screwdriver.
    • Remove the speaker rail vertically from the device.
  15. Sony Clie PEG-NR70 Motherboard Replacement, Motherboard: Schritt 15, Bild 1 von 1
    • Unplug the ribbon cable found near the bottom of the motherboard by pulling it towards the bottom of the device.
    • Be careful not to tear the plug! It is very thin.
  16. Sony Clie PEG-NR70 Motherboard Replacement: Schritt 16, Bild 1 von 2 Sony Clie PEG-NR70 Motherboard Replacement: Schritt 16, Bild 2 von 2
    • Unplug the ribbon cable connected at the bottom of the memory module by prying it up with a spudger.
  17. Sony Clie PEG-NR70 Motherboard Replacement: Schritt 17, Bild 1 von 1
    • Unplug the wires found underneath the right side of the "stem" of the motherboard by pulling gently.
    • Be careful not to tear the wires! They are very thin.
  18. Sony Clie PEG-NR70 Motherboard Replacement: Schritt 18, Bild 1 von 1
    • Lift up the black locking tab holding the ribbon cable in place.
    • Gently pull on the ribbon cable to remove it from the ZIF connector.
    • Be careful not to tear the ribbon cable! It is very thin.
  19. Sony Clie PEG-NR70 Motherboard Replacement: Schritt 19, Bild 1 von 1
    • Unplug the yellow connector from the underside of the left side of the motherboard by pulling gently.
  20. Sony Clie PEG-NR70 Motherboard Replacement: Schritt 20, Bild 1 von 1
    • Unplug the second yellow connector from the underside of the right side of the motherboard by pulling gently.
  21. Sony Clie PEG-NR70 Motherboard Replacement: Schritt 21, Bild 1 von 1
    • Unplug the last set of wires from underneath the top of the motherboard.
    • The motherboard should be loose now. You should be able to wiggle it free from the housing.
Abschluss
Daniel Soski
57 Reputation
6 Anleitungen geschrieben
Cal Poly, Team 14-11, Maness Spring 2013 Mitglied von Cal Poly, Team 14-11, Maness Spring 2013
CPSU-MANESS-S13S14G11
5 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 6
Insgesamt: 669
