Einleitung
Installing a new motherboard involves removing the other components. Once this is done, removing the motherboard involves unscrewing the board from the housing and disconnecting various cables and wires.
Was du brauchst
Unscrew the 1.9mm screw located at the top of the device with a Phillips #00 screwdriver.
Unscrew the 2.5mm screw located on the left side of the device with a Phillips #00 screwdriver.
Unscrew the five 2.5mm screws on the back panel with a Phillips #00 screwdriver.
Remove the back panel by lifting it away with your hands.
Pull up on the black tab on the battery pack to reveal the power cord.
Disconnect the battery pack from the motherboard by unplugging the power cables. Gently pull the wire toward the bottom of the device.
Gently peel back the adhesive to completely disconnect the battery pack from device.
Holding the memory module in place, unscrew the three 0.9mm screws with a Phillips #00 screwdriver.
Unscrew the 2.5mm screw on the top portion of the audio module with a Phillips #00 screwdriver.
Lift up the orange ribbon cable and unscrew the two 2.5mm screws located at the corners of the audio module with a Phillips #00 screwdriver.
Unplug the audio module from the motherboard by disconnecting the wires by lifting the orange wire up.
Holding down the speaker rail unscrew the two 2.5mm screws with a Phillips #00 screwdriver.
Remove the speaker rail vertically from the device.
Unplug the ribbon cable found near the bottom of the motherboard by pulling it towards the bottom of the device.
Unplug the ribbon cable connected at the bottom of the memory module by prying it up with a spudger.
Unplug the wires found underneath the right side of the "stem" of the motherboard by pulling gently.
Lift up the black locking tab holding the ribbon cable in place.
Gently pull on the ribbon cable to remove it from the ZIF connector.
Unplug the yellow connector from the underside of the left side of the motherboard by pulling gently.
Unplug the second yellow connector from the underside of the right side of the motherboard by pulling gently.
Unplug the last set of wires from underneath the top of the motherboard.
The motherboard should be loose now. You should be able to wiggle it free from the housing.
