Zum Hauptinhalt wechseln
Toshiba Satellite L455-S5975 Logic Board Replacement
Was du brauchst
  1. Toshiba Satellite L455-S5975 Logic Board Replacement, Keyboard: Schritt 1, Bild 1 von 2 Toshiba Satellite L455-S5975 Logic Board Replacement, Keyboard: Schritt 1, Bild 2 von 2
    • Before repairing your laptop, power down the system, disconnect the charger if necessary and remove the battery.
    • Use the flat edge of the plastic opening tool to pry open the narrow plastic strip above the keyboard.
  2. Toshiba Satellite L455-S5975 Logic Board Replacement: Schritt 2, Bild 1 von 1
    • Remove the three 3mm screws with a Phillips#00 Screwdriver.
  3. Toshiba Satellite L455-S5975 Logic Board Replacement: Schritt 3, Bild 1 von 1
    • Lift the keyboard away from the top side of the laptop.
    • Do not pull the keyboard away too hard. It is still connected by the fragile ribbon cable (shown in the red square).
  4. Toshiba Satellite L455-S5975 Logic Board Replacement: Schritt 4, Bild 1 von 2 Toshiba Satellite L455-S5975 Logic Board Replacement: Schritt 4, Bild 2 von 2
    • Disconnect the keyboard cable that is still attached to the keyboard.
    • Unlatch the fastener.
    • Using your hands, pull the keyboard connector out, not up.
  5. Toshiba Satellite L455-S5975 Logic Board Replacement, Fan: Schritt 5, Bild 1 von 2 Toshiba Satellite L455-S5975 Logic Board Replacement, Fan: Schritt 5, Bild 2 von 2
    • Flip the laptop over to access the battery.
    • Remove the battery by sliding fingers away from each other and lifting up the tab at the same time.
  6. Toshiba Satellite L455-S5975 Logic Board Replacement: Schritt 6, Bild 1 von 1
    • Remove the twelve 10mm screws with a Phillips #00 screwdriver.
    • Remove the cover over the hard drive (upper right in photo) and remove the four 10mm screws at the four corners.
  7. Toshiba Satellite L455-S5975 Logic Board Replacement: Schritt 7, Bild 1 von 1
    • Remove the three 4mm screws with a Phillips #00 screwdriver.
  8. Toshiba Satellite L455-S5975 Logic Board Replacement: Schritt 8, Bild 1 von 1
    • Flip the laptop over so it's in the right-side-up position.
    • Lift the grey plastic casing up and unhook any wires attached to the casing.
    • Remove the five 10mm screws, each with a label 'F10' next to them.
  9. Toshiba Satellite L455-S5975 Logic Board Replacement: Schritt 9, Bild 1 von 2 Toshiba Satellite L455-S5975 Logic Board Replacement: Schritt 9, Bild 2 von 2
    • Disconnect the flat thin wire connecting the track pad to the motherboard by pulling it straight out.
    • Disconnect the thin red wire on the right side of the motherboard.
  10. Toshiba Satellite L455-S5975 Logic Board Replacement: Schritt 10, Bild 1 von 1
    • Remove the two 6mm screws with a Phillips #00 screwdriver.
  11. Toshiba Satellite L455-S5975 Logic Board Replacement: Schritt 11, Bild 1 von 2 Toshiba Satellite L455-S5975 Logic Board Replacement: Schritt 11, Bild 2 von 2
    • Disconnect the red and yellow wires connecting the fan to the motherboard by pulling the wires straight out.
    • Remove the fan.
  12. Toshiba Satellite L455-S5975 Logic Board Replacement, Logic Board: Schritt 12, Bild 1 von 1
    • Remove the following with a Phillips #00 Screwdriver:
    • Six 7mm Phillips Head screws
    • One 5 mm Phillips Head screw
    • Remove the LCD screen tab
  13. Toshiba Satellite L455-S5975 Logic Board Replacement: Schritt 13, Bild 1 von 2 Toshiba Satellite L455-S5975 Logic Board Replacement: Schritt 13, Bild 2 von 2
    • A red wire connects the motherboard to the computer, so release the wire by pulling it straight out.
    • After all the screws are removed, lift the motherboard up and away from the earphone jacks that are located at the front of the laptop.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Mike Kennedy
160 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 2-21, Maness Spring 2013 Mitglied von Cal Poly, Team 2-21, Maness Spring 2013
CPSU-MANESS-S13S2G21
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 6
Insgesamt: 3,036
