Zum Hauptinhalt wechseln
Removing the Dell Inspiron 1150 Keyboard
Was du brauchst
  1. Removing the Dell Inspiron 1150 Keyboard, Removing Dell Inspiron 1150 Battery: Schritt 1, Bild 1 von 3 Removing the Dell Inspiron 1150 Keyboard, Removing Dell Inspiron 1150 Battery: Schritt 1, Bild 2 von 3 Removing the Dell Inspiron 1150 Keyboard, Removing Dell Inspiron 1150 Battery: Schritt 1, Bild 3 von 3
    • Place the laptop upside down on a clean, flat surface.
    • Locate the battery release button with the padlock symbol above it.
    • Slide the battery release button towards the padlock symbol and hold it there. Note that the button is spring loaded and will return if released.
    • The battery is now released from the battery compartment.
    • Gently remove the battery from the side of the laptop.
  2. Removing the Dell Inspiron 1150 Keyboard, Keyboard: Schritt 2, Bild 1 von 3 Removing the Dell Inspiron 1150 Keyboard, Keyboard: Schritt 2, Bild 2 von 3 Removing the Dell Inspiron 1150 Keyboard, Keyboard: Schritt 2, Bild 3 von 3
    • Use a spudger to lift the notched right edge of the hinge cover, and pry it loose
    • You need to lay the LCD screen down flat to allow the hinge cover to be lifted off
    • Lift the hinge cover off and set aside
  3. Removing the Dell Inspiron 1150 Keyboard: Schritt 3, Bild 1 von 3 Removing the Dell Inspiron 1150 Keyboard: Schritt 3, Bild 2 von 3 Removing the Dell Inspiron 1150 Keyboard: Schritt 3, Bild 3 von 3
    • Remove 4ea M2 x 3mm keyboard screws
    • Lift up keyboard from the rear to expose the connector below
    • Disconnect the keyboard ribbon cable from the mother board
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Richdave
32.051 Reputation
30 Anleitungen geschrieben
Master Techs Mitglied von Master Techs
Community
322 Mitglieder
2.521 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 4
Insgesamt: 866
