Zum Hauptinhalt wechseln
Nikon Coolpix S630 Shutter Button Replacement
Was du brauchst
  1. Nikon Coolpix S630 Shutter Button Replacement, Battery Compartment: Schritt 1, Bild 1 von 1
    • The battery compartment is located on the bottom of the camera.
    • Place your thumb on the battery door.
    • Slide the door away from the camera in the direction the arrow points to.
  2. Nikon Coolpix S630 Shutter Button Replacement, Battery: Schritt 2, Bild 1 von 1
    • Slide the yellow tab towards the back of the camera.
    • The battery should pop out.
    • Remove the battery.
  3. Nikon Coolpix S630 Shutter Button Replacement, Memory Card: Schritt 3, Bild 1 von 1
    • Press the memory card down into the camera.
    • The memory card should pop out.
    • Remove the memory card.
  4. Nikon Coolpix S630 Shutter Button Replacement, Front Cover: Schritt 4, Bild 1 von 1
    • Locate a small, rectangular flap above the battery cover door.
    • Push the small, rectangular flap back through the hole.
  5. Nikon Coolpix S630 Shutter Button Replacement: Schritt 5, Bild 1 von 1
    • Using the plastic opening tool, gently pry open the front cover. Gently remove the front cover.
    • Make sure to hold the camera down when removing the front cover.
  6. Nikon Coolpix S630 Shutter Button Replacement, Shutter Button: Schritt 6, Bild 1 von 1
    • Place the front cover facing down so that you can easily see the shutter button.
  7. Nikon Coolpix S630 Shutter Button Replacement: Schritt 7, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Using tweezers, gently slide the shutter button out.
    • Be very gentle because you can damage the piece.
Abschluss
Cal Poly, Team 8-56, Johann Spring 2013 Mitglied von Cal Poly, Team 8-56, Johann Spring 2013
CPSU-JOHANN-S13S8G56
4 Mitglieder
18 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 9
Letzte 30 Tage: 37
Insgesamt: 2,190
