Zum Hauptinhalt wechseln
HP Pavilion DV2160BR RAM Replacement
Was du brauchst
  1. HP Pavilion DV2160BR RAM Replacement, RAM: Schritt 1, Bild 1 von 2 HP Pavilion DV2160BR RAM Replacement, RAM: Schritt 1, Bild 2 von 2
    • Start with the bottom of the laptop facing up.
    • Locate the panel that is covering the RAM compartment.
    • Unscrew the two 5mm Phillips #0 screws that are securing the RAM compartment.
  2. HP Pavilion DV2160BR RAM Replacement: Schritt 2, Bild 1 von 2 HP Pavilion DV2160BR RAM Replacement: Schritt 2, Bild 2 von 2
    • Lift up the panel that is by the end that held the screws. Set it aside.
  3. HP Pavilion DV2160BR RAM Replacement: Schritt 3, Bild 1 von 3 HP Pavilion DV2160BR RAM Replacement: Schritt 3, Bild 2 von 3 HP Pavilion DV2160BR RAM Replacement: Schritt 3, Bild 3 von 3
    • Using 2 prying tools, push the 2 buttons on the sides of one RAM module simultaneously, so that one side of the module pops up and out of the clips holding it down.
    • Grab the RAM module and carefully pull it straight out of its slot.
    • Repeat this step for the second RAM module, which is located just underneath the first RAM module.
Abschluss
Shannon
55 Reputation
6 Anleitungen geschrieben
Cal Poly, Team 13-66, Johann Spring 2013 Mitglied von Cal Poly, Team 13-66, Johann Spring 2013
CPSU-JOHANN-S13S13G66
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 12
Insgesamt: 368
