Einleitung
If the side keys of your LG VX8560 are sticky or stop functioning you may want to replace them. Follow this guide to access the side buttons of your LG VX8560 phone.
Was du brauchst
Push the battery cover from the indentation and slide the battery cover away from phone to remove battery cover
Using a Phillips #00 screwdriver, remove all four screws that are visible along the edge of the phone
Find the seam between the phone’s keypad cover and back cover, and slide a plastic pry tool along the edge to gently pry the two pieces apart without completely separating them.
Place the side keys so that they are aligned with the silver circles located on the side of the motherboard.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
