Zum Hauptinhalt wechseln
Nishiki Aero II Front Inner Tube Replacement
Was du brauchst
  1. Nishiki Aero II Front Inner Tube Replacement, Removing Road Bike Front Wheel: Schritt 1, Bild 1 von 1
    • Turn the bike upside down.
  2. Nishiki Aero II Front Inner Tube Replacement: Schritt 2, Bild 1 von 1
    • Use a wrench to loosen the nut holding the wheel's axle on one side.
    • Once it's loose enough, continue removing the nut with your hand.
  3. Nishiki Aero II Front Inner Tube Replacement: Schritt 3, Bild 1 von 2 Nishiki Aero II Front Inner Tube Replacement: Schritt 3, Bild 2 von 2
    • After removing the nut, also remove the washer under it.
    • Keep note of how the washer has a small appendage that locks into a slot in the fork.
  4. Nishiki Aero II Front Inner Tube Replacement: Schritt 4, Bild 1 von 1
    • Follow the previous steps for the opposite side.
  5. Nishiki Aero II Front Inner Tube Replacement: Schritt 5, Bild 1 von 1
    • Lift the wheel up from the fork.
  6. Nishiki Aero II Front Inner Tube Replacement, Nishiki Aero II Tire Removal: Schritt 6, Bild 1 von 2 Nishiki Aero II Front Inner Tube Replacement, Nishiki Aero II Tire Removal: Schritt 6, Bild 2 von 2
    • Unscrew the cap from the air valve.
    • Release the tire's air by pressing a thin object on the center pin of the valve.
    • A hex wrench or any blunt object can be used.
  7. Nishiki Aero II Front Inner Tube Replacement: Schritt 7, Bild 1 von 3 Nishiki Aero II Front Inner Tube Replacement: Schritt 7, Bild 2 von 3 Nishiki Aero II Front Inner Tube Replacement: Schritt 7, Bild 3 von 3
    • Wedge a tire lever between the tire and the rim. Grab the tire with the lever's inward scoop.
    • Grab the tire's edge with the lever and pull it back to scoop the tire from the rim.
    • Keep the tire lever anchored on a spoke with the notch on the lever's opposite end.
  8. Nishiki Aero II Front Inner Tube Replacement: Schritt 8, Bild 1 von 2 Nishiki Aero II Front Inner Tube Replacement: Schritt 8, Bild 2 von 2
    • Repeat with an additional tire lever five inches away from the other.
  9. Nishiki Aero II Front Inner Tube Replacement: Schritt 9, Bild 1 von 3 Nishiki Aero II Front Inner Tube Replacement: Schritt 9, Bild 2 von 3 Nishiki Aero II Front Inner Tube Replacement: Schritt 9, Bild 3 von 3
    • Repeat with a third tire lever farther around the tire.
    • Alternate lifting the second and third levers until the tire comes partway off.
  10. Nishiki Aero II Front Inner Tube Replacement: Schritt 10, Bild 1 von 3 Nishiki Aero II Front Inner Tube Replacement: Schritt 10, Bild 2 von 3 Nishiki Aero II Front Inner Tube Replacement: Schritt 10, Bild 3 von 3
    • Wedge the tire off of the other rim with the tire levers.
    • Pull the air valve from its hole in the rim to completely remove the tire.
  11. Nishiki Aero II Front Inner Tube Replacement, Front Inner Tube: Schritt 11, Bild 1 von 1
    • Now that the tire and tube are off of the rim, gently pull the tube out of the tire.
    • Be sure to pull gently, as the tube could potentially end up adhered to the inside of the tire.
  12. Nishiki Aero II Front Inner Tube Replacement: Schritt 12, Bild 1 von 1
    • Now, you've separated your tube, tire and rim.
    • To replace the tube, follow these instructions in reverse order using the new or patched tube.
    • Remember to inflate just a little bit of air into the tube before you try to install it, as that makes the process go much smoother.
Abschluss
Tobias Elder
113 Reputation
7 Anleitungen geschrieben
Cal Poly, Team 21-53, Johann Spring 2013 Mitglied von Cal Poly, Team 21-53, Johann Spring 2013
CPSU-JOHANN-S13S21G53
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 1,478
