Zum Hauptinhalt wechseln
Microsoft Zune HD Lower Rear Panel Replacement
Was du brauchst
  1. Microsoft Zune HD Lower Rear Panel Replacement, Upper Rear Panel: Schritt 1, Bild 1 von 1
    • Remove the four Tri-Wing screws securing the upper rear panel to the inner chassis.
  2. Microsoft Zune HD Lower Rear Panel Replacement: Schritt 2, Bild 1 von 2 Microsoft Zune HD Lower Rear Panel Replacement: Schritt 2, Bild 2 von 2
    • Slightly rotate the top edge of the upper rear panel away from the Zune.
    • Lift the upper rear panel straight up off the black plastic lower rear panel.
  3. Microsoft Zune HD Lower Rear Panel Replacement, Lower Rear Panel: Schritt 3, Bild 1 von 2 Microsoft Zune HD Lower Rear Panel Replacement, Lower Rear Panel: Schritt 3, Bild 2 von 2
    • Insert a small Zune opening tool into the gap between the logic board and one side of the black plastic lower rear panel.
    • Carefully twist the Zune opening tool to pop the lower rear panel off the clips attaching it to the Zune.
    • Repeat this process for the other side of the lower rear panel.
  4. Microsoft Zune HD Lower Rear Panel Replacement: Schritt 4, Bild 1 von 1
    • Carefully slide the lower rear panel away from the Zune.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 19
Insgesamt: 3,131
