Zum Hauptinhalt wechseln
Wie man ausgeleierte Inbus-Senkschrauben ausdreht
Was du brauchst
  1. Wie man ausgeleierte Inbus-Senkschrauben ausdreht, Wie man ausgeleierte Inbus-Senkschrauben ausdreht: Schritt 1, Bild 1 von 1
    • Schneide einen Schlitz in den Kopf.
    • Setze einen Flachschraubendreher am Schlitz an und hämmere leicht dagegen, so dass sich die Schraube gegen den Uhrzeigersinn lockert.
    • Drehe sie dann ganz heraus.
Ziellinie
44 weitere Nutzer:innen haben diese Anleitung absolviert.
en de
100%
VauWeh hilft uns, die Welt in Ordnung zu bringen! Wie kann ich mithelfen?
Hier starten ›
Wolfgang
597 Reputation
2 Anleitungen geschrieben
6 Kommentare
Use the same technique for Philips or crosshead screws.
Use a grinding / cutting disk, not a saw blade. Apply the rotating cutting disk gently, do not force or it will break.
If this is a toughened steel or stainless steel bolt (much tougher), it will be best to use a reinforced cutting disk.
Use a dusk mask to avoid breathing the dusk from the disk !
(No, I don't usually, but I should !)
Frank B - Antwort
While this works it is very difficult to not ruin the material around the bolt.
What I do is use a torx bit. size one up that is slightly larger then the hole and then firmly tap it in. atttach your drive handle a turn slowly while pushing down. this will normally break it free.
Also before your get to this point try putting your allen key in the hole and smack it with a hammer. sometimes the force of the hit will cause the metal to "break" enough that the allen screw wont strip.
Jamie Mcguire -
There are also specifically designed screw extractors made for this. These tools are generally two-sided: one side is used to drill the hole, while the other is inserted to extract. If the process works, the surrounding area is undamaged.
Karl Kaufmann - Antwort
Use another Allen bolt to weld over it and then you can easily remove the Allen bolt with the help of Allen key
Tushar Pednekar - Antwort
And if for any reason if you can't weld then just drill the head of the Allen bolt so it's shears off. And then u can easily remove the rest
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 12
Letzte 7 Tage: 127
Letzte 30 Tage: 467
Insgesamt: 258,614
