Einleitung
The screens for the LG VX5600 come together as a single unit inside the phone therefore to replace one you will be replacing the other.
Was du brauchst
Hold your phone with the back casing facing you and the bottom of the phone towards the sky.
Push down on the cover and slide down to remove. You should only have to apply minimal pressure.
Insert your finger into the small indentation above the battery.
Push down on the battery and pull it away from the phone; it will pop out.
Use tweezers to remove the two rubber covers found at the left and right corners below the inside screen.
Grasp the phone and rotate it 90 degrees counterclockwise for a better grip.
Unscrew the two 3.0-mm Phillips #000 screws, found under the rubber covers at the bottom left and right corners.
Hold the opened phone upright.
Use the spudger to pry around the edges of the phone and detach the tabs.
Use your finger to lift up the grey plastic cover.
Use the tweezers to grasp the plastic screen, and pull the plastic screen protector up and out of the phone.
Use one hand to grasp the phone and prop the inner grey casing up.
Unscrew the two 3.0-mm Phillips #000 screws located in the upper left and right hand corners.
Using your hands hold the inner grey casing up and pull on the black plastic that surrounds the screen away from the outer grey casing.
Using tweezers, pull the vibration motor away from the outer grey casing and towards the black plastic surrounding the screens.
Flip the phone closed so that the top outer casing is facing you.
Lift up on the the outer grey casing, completely removing it from the phone.
Grasp the phone with one hand, and use the tweezers with the other hand to pull up on the flex cable disconnecting it from the screen.
Use your fingers to lift up the detached flex cable and use the tweezers to lift the LCD screen component out of the phone casing.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
just swapped screens Perfect. step 5 is harder than it look but take time and go easy, I used a 1/8 in blade screwdriver.
