Zum Hauptinhalt wechseln
Kindle 1st Generation SD Card Reader Replacement
Was du brauchst
  1. Kindle 1st Generation SD Card Reader Replacement, Battery: Schritt 1, Bild 1 von 1
    • Slide the grey plastic cover laterally off the back of the device.
  2. Kindle 1st Generation SD Card Reader Replacement: Schritt 2, Bild 1 von 2 Kindle 1st Generation SD Card Reader Replacement: Schritt 2, Bild 2 von 2
    • Use a plastic opening tool to lift the battery on the side closest to the edge of the device.
    • Unplug the battery from the device by pinching the white connector and pulling.
    • Do not yank the battery or try to disconnect the battery by pulling the wires.
  3. Kindle 1st Generation SD Card Reader Replacement, SD Card Reader: Schritt 3, Bild 1 von 1
    • Unscrew eight (8) Phillips #00 screws (3 mm).
  4. Kindle 1st Generation SD Card Reader Replacement: Schritt 4, Bild 1 von 2 Kindle 1st Generation SD Card Reader Replacement: Schritt 4, Bild 2 von 2
    • Start at one side of the device. Use a plastic opening tool to separate the casing of the device. Slowly work your way around the entire device.
    • Avoid prying between the buttons and the device. This could cause damage to the buttons.
  5. Kindle 1st Generation SD Card Reader Replacement: Schritt 5, Bild 1 von 2 Kindle 1st Generation SD Card Reader Replacement: Schritt 5, Bild 2 von 2
    • Unscrew the two (2) Phillips #00 screws (3 mm) which fasten the metal casing shield.
    • Slowly remove the metal casing shield by lifting it and carefully peeling up the tape.
  6. Kindle 1st Generation SD Card Reader Replacement: Schritt 6, Bild 1 von 1
    • Remove the four (4) Phillips #00 screws (3 mm) which fasten the SD Card Reader.
  7. Kindle 1st Generation SD Card Reader Replacement: Schritt 7, Bild 1 von 2 Kindle 1st Generation SD Card Reader Replacement: Schritt 7, Bild 2 von 2
    • Lift the flap attaching the blue and white ribbon cable to the motherboard by lifting it vertically with a spudger.
    • The flap is connected via a hinge. Once you lift the flap, it will stay up and the cable will be lose. Remember to snap it back down during reassembly.
    • Carefully lift the SD Card Reader vertically from the motherboard.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 13
Insgesamt: 1,719
