Zum Hauptinhalt wechseln
Replacing 1995-1999 Dodge Neon Spark Plugs
  1. Replacing 1995-1999 Dodge Neon Spark Plugs, Spark Plugs: Schritt 1, Bild 1 von 1
    • The air vent is covering 4 spark plugs.
    • Twist off the wing nut on the left (see hand in photo).
    • The big plastic art with the "SO??" marked on it just lifts up and out
    • It sounds like you are breaking something but you are just disconnecting it from the air filter housing.
  2. Replacing 1995-1999 Dodge Neon Spark Plugs: Schritt 2, Bild 1 von 1
    • Image of engine with out plastic cover that was removed in step 1. See the air filter exposed in the back?
    • There are numbers on the top of the engine with wires going to the four spark plugs in the front of the engine (between the oil dipstick and the oil repository).
    • Start with s
Abschluss
5 weitere Nutzer:innen haben diese Anleitung absolviert.
Benjamin
213 Reputation
1 Anleitung geschrieben
2 Kommentare
How long of an extention rachet do you need to get to the plugs..? Thanks though seems simple enough. Also has anyone changed their plugs in a 98 neon using Bosch Platinum IR infusion plugs... with 4 ground electrodes... I just bought them.. figured they'd work the best... hope not to hot.
Shawn - Antwort
I look up different things for my 98' Plymouth neon and always see 2000, or 02' I'm guessing they haven't changed much. Happy to see it with the correct year. Thanks agsin.
Shawn - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 16
Insgesamt: 4,242
