Einleitung
Use this guide to replace RAM/Memory modules in a Toshiba Portege R705-P25.
What is Random Access Memory (RAM)? Check out this iFixit page about Computer Memory to learn.
Some common reasons for this guide are replacing faulty memory modules/sticks or simply upgrading the pre-existing ones.
-Be careful on selecting new RAM modules as they may not be compatible with older laptops like this Toshiba Portege. Please refer to the Parts list to see what type of RAM would work best with this laptop or the Detailed Product Specification.
This guide instructs you how to locate the RAM access panel on the back and unscrew it. Then replace the RAM sticks. For extra help, please refer to the Service Manual (Pages 51-59).
Was du brauchst
Turn the computer over and locate the RAM access panel (bracketed with yellow lines).
Locate the head of each screw (highlighted in yellow). Using a small Phillips head screwdriver, fit the metal cross shaped point into the head of each screw.
Apply medium-light pressure to the screwdriver and rotate counter-clockwise to unscrew the RAM access panel. Do this for both screws.
Use your finger or screwdriver to remove the panel by gently lifting from the lip next to the icon indicated in red.
Locate the small metal tabs on either side of the top RAM stick/module marked by the red arrows. Then, gently pull them apart simultaneously to pop-up/unlock the RAM module.
Gently pull the RAM module out of its housing at the ~30° angle it rests at. Proceed to store the loose RAM modules in a safe place.
To remove the second (lower) module, repeat Step 3 and Step 4.
To insert the new RAM module, locate the appropriate RAM housing and place the module diagonally into the slot.
Next, gently push the module down towards and into the laptop until the small metal tabs acoustically snap into place.
If desired, repeat the last two steps for installing the top module.
Once the desired amount of RAM is installed flush to the laptop backing, re-cover the area with the RAM access panel and gently screw clockwise back into place.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
