Zum Hauptinhalt wechseln
Lenovo bluetooth mouse N6901A disassembly
Was du brauchst
  1. Lenovo bluetooth mouse N6901A disassembly, Mouse: Schritt 1, Bild 1 von 1
    • 3 Phillips screws are located under the battery cover, unscrew them
  2. Lenovo bluetooth mouse N6901A disassembly: Schritt 2, Bild 1 von 2 Lenovo bluetooth mouse N6901A disassembly: Schritt 2, Bild 2 von 2
    • The mouse cover at the bottom should move freely but at the top is hold by 2 brackets
    • In order to remove the mouse cover, you will need to rock left/right the cover and slide it down (from scroll wheel toward the Lenovo logo)
  3. Lenovo bluetooth mouse N6901A disassembly: Schritt 3, Bild 1 von 2 Lenovo bluetooth mouse N6901A disassembly: Schritt 3, Bild 2 von 2
    • At this point, you have separated the mouse cover
  4. Lenovo bluetooth mouse N6901A disassembly: Schritt 4, Bild 1 von 1
    • Use the appropriate tool to remove gently the power connector. Don't use your finger, you might brake the cable
  5. Lenovo bluetooth mouse N6901A disassembly: Schritt 5, Bild 1 von 2 Lenovo bluetooth mouse N6901A disassembly: Schritt 5, Bild 2 von 2
    • The micro switch can be replaced by OMRON D2FC-F-7N but you need to trim the solder terminals with a flush wire cutter
    • When you reassemble the mouse, make sure you don't crush the power cable
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Shinn Chyang Chen
2.953 Reputation
3 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 11
Letzte 30 Tage: 34
Insgesamt: 5,542
