Zum Hauptinhalt wechseln
Bush Pump Head and Handle Replacement
  1. Bush Pump Head and Handle Replacement, Head and Handle: Schritt 1, Bild 1 von 2 Bush Pump Head and Handle Replacement, Head and Handle: Schritt 1, Bild 2 von 2
    • Test pump performance by pumping 40 strokes.
    • An effective pump should return at least 10 liters.
  2. Bush Pump Head and Handle Replacement: Schritt 2, Bild 1 von 2 Bush Pump Head and Handle Replacement: Schritt 2, Bild 2 von 2
    • Remove the two pins connecting the handle to the slider.
  3. Bush Pump Head and Handle Replacement: Schritt 3, Bild 1 von 2 Bush Pump Head and Handle Replacement: Schritt 3, Bild 2 von 2
    • Pull the two lever arms away from the slider.
  4. Bush Pump Head and Handle Replacement: Schritt 4, Bild 1 von 2 Bush Pump Head and Handle Replacement: Schritt 4, Bild 2 von 2
    • Lift the two pins attaching the pump frame to the head and handle up, off of the pump frame.
  5. Bush Pump Head and Handle Replacement: Schritt 5, Bild 1 von 3 Bush Pump Head and Handle Replacement: Schritt 5, Bild 2 von 3 Bush Pump Head and Handle Replacement: Schritt 5, Bild 3 von 3
    • Throughout this step, make sure you support the handle and head with at least three hands.
    • Slide the bearing rod out of the head.
    • Inspect the bearing rod and head for any wear or tear.
  6. Bush Pump Head and Handle Replacement: Schritt 6, Bild 1 von 1
    • Remove the head and handle, and place them on a clean surface to prevent contamination.
Abschluss
Jake Devincenzi
117.277 Reputation
57 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 164
