Zum Hauptinhalt wechseln
Power Mac G4 MDD AirPort Card Replacement
Was du brauchst
  1. Power Mac G4 MDD AirPort Card Replacement, Case: Schritt 1, Bild 1 von 2 Power Mac G4 MDD AirPort Card Replacement, Case: Schritt 1, Bild 2 von 2
    • The Power Mac G4 MDD: the last, and the fastest G4-based Mac. This computer boasted up to a Dual 1.42GHz PowerPC G4 CPU (though I have a single 1.25GHz).
    • Two USB 1.1 Ports
    • Assorted Audio
    • Video (ADC & DVI)
    • Networking (RJ-45 Ethernet/56k Modem)
    • Some later model MDD's (such as the dual 1.42GHz) Have a FireWire 800 Port Here:
  2. Power Mac G4 MDD AirPort Card Replacement: Schritt 2, Bild 1 von 3 Power Mac G4 MDD AirPort Card Replacement: Schritt 2, Bild 2 von 3 Power Mac G4 MDD AirPort Card Replacement: Schritt 2, Bild 3 von 3
    • Unplug the computer.
    • Unplug the power supply and all external connections from the computer.
    • Pull on the side lever and lower the side of the case.
  3. Power Mac G4 MDD AirPort Card Replacement, AirPort Card: Schritt 3, Bild 1 von 3 Power Mac G4 MDD AirPort Card Replacement, AirPort Card: Schritt 3, Bild 2 von 3 Power Mac G4 MDD AirPort Card Replacement, AirPort Card: Schritt 3, Bild 3 von 3
    • The AirPort card is located next to the graphics card.
    • If your computer has a FireWire 800 port between the FireWire 400 Ports and the Ethernet Ports then your computer uses an AirPort Extreme 802.11g Card (See Related Parts). If your computer has no firewire 800 port, then your computer uses an 802.11b AirPort PCMCIA Card (Also See Related Parts). Removal of both cards is pretty much the same.
    • First disconnect the antenna from the card, it may be helpful to use a spudger or flathead screwdriver.
    • Now, grasp the plastic tab on the back of the card and pull it out of the computer.
  4. Power Mac G4 MDD AirPort Card Replacement: Schritt 4, Bild 1 von 1
    • The Airport 802.11b PCMCIA Card.
Abschluss
13 weitere Nutzer:innen haben diese Anleitung absolviert.
Chris Green
36.978 Reputation
49 Anleitungen geschrieben
Master Techs Mitglied von Master Techs
Community
322 Mitglieder
2.528 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 24
Insgesamt: 28,632
