Zum Hauptinhalt wechseln
Bush Pump Above Grade Riser Pipe Replacement
Was du brauchst
  1. Bush Pump Above Grade Riser Pipe Replacement, Head and Handle: Schritt 1, Bild 1 von 2 Bush Pump Above Grade Riser Pipe Replacement, Head and Handle: Schritt 1, Bild 2 von 2
    • Test pump performance by pumping 40 strokes.
    • An effective pump should return at least 10 liters.
  2. Bush Pump Above Grade Riser Pipe Replacement: Schritt 2, Bild 1 von 2 Bush Pump Above Grade Riser Pipe Replacement: Schritt 2, Bild 2 von 2
    • Remove the two pins connecting the handle to the slider.
  3. Bush Pump Above Grade Riser Pipe Replacement: Schritt 3, Bild 1 von 2 Bush Pump Above Grade Riser Pipe Replacement: Schritt 3, Bild 2 von 2
    • Pull the two lever arms away from the slider.
  4. Bush Pump Above Grade Riser Pipe Replacement: Schritt 4, Bild 1 von 2 Bush Pump Above Grade Riser Pipe Replacement: Schritt 4, Bild 2 von 2
    • Lift the two pins attaching the pump frame to the head and handle up, off of the pump frame.
  5. Bush Pump Above Grade Riser Pipe Replacement: Schritt 5, Bild 1 von 3 Bush Pump Above Grade Riser Pipe Replacement: Schritt 5, Bild 2 von 3 Bush Pump Above Grade Riser Pipe Replacement: Schritt 5, Bild 3 von 3
    • Throughout this step, make sure you support the handle and head with at least three hands.
    • Slide the bearing rod out of the head.
    • Inspect the bearing rod and head for any wear or tear.
  6. Bush Pump Above Grade Riser Pipe Replacement: Schritt 6, Bild 1 von 1
    • Remove the head and handle, and place them on a clean surface to prevent contamination.
  7. Bush Pump Above Grade Riser Pipe Replacement, Riser Main Slider: Schritt 7, Bild 1 von 2 Bush Pump Above Grade Riser Pipe Replacement, Riser Main Slider: Schritt 7, Bild 2 von 2
    • Firmly lift the riser main slider with two hands.
    • Use caution not to drop the riser main, as this can damage the pump cylinder.
  8. Bush Pump Above Grade Riser Pipe Replacement: Schritt 8, Bild 1 von 3 Bush Pump Above Grade Riser Pipe Replacement: Schritt 8, Bild 2 von 3 Bush Pump Above Grade Riser Pipe Replacement: Schritt 8, Bild 3 von 3
    • Use a pipe wrench to fully loosen the above grade riser pipe.
  9. Bush Pump Above Grade Riser Pipe Replacement: Schritt 9, Bild 1 von 3 Bush Pump Above Grade Riser Pipe Replacement: Schritt 9, Bild 2 von 3 Bush Pump Above Grade Riser Pipe Replacement: Schritt 9, Bild 3 von 3
    • Lift the slider and riser main pipe.
    • Place a pump rod clamp around the rod, and tighten it securely against the pump rod.
    • Carefully lower the riser main and slider to allow it to rest on the rod clamp.
  10. Bush Pump Above Grade Riser Pipe Replacement: Schritt 10, Bild 1 von 3 Bush Pump Above Grade Riser Pipe Replacement: Schritt 10, Bild 2 von 3 Bush Pump Above Grade Riser Pipe Replacement: Schritt 10, Bild 3 von 3
    • Loosen and remove both the pump rod jam nut and pump rod nut on the top of the slider.
  11. Bush Pump Above Grade Riser Pipe Replacement: Schritt 11, Bild 1 von 2 Bush Pump Above Grade Riser Pipe Replacement: Schritt 11, Bild 2 von 2
    • Remove the riser main slider, and inspect it for wear and tear.
    • Set the slider in a sanitary place to prevent contamination.
  12. Bush Pump Above Grade Riser Pipe Replacement, Above Grade Riser Pipe: Schritt 12, Bild 1 von 3 Bush Pump Above Grade Riser Pipe Replacement, Above Grade Riser Pipe: Schritt 12, Bild 2 von 3 Bush Pump Above Grade Riser Pipe Replacement, Above Grade Riser Pipe: Schritt 12, Bild 3 von 3
    • Remove the above grade riser pipe.
    • Firmly screw a T-handle onto the pump rod.
    • If you are replacing the above ground riser main, leave the T-handle attached until you are ready to install the replacement part.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Jake Devincenzi
117.328 Reputation
57 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 20
Insgesamt: 436
