Zum Hauptinhalt wechseln
Samsung Epic 4G Touch Battery Replacement
Was du brauchst
  1. Samsung Epic 4G Touch Battery Replacement, Rear Case: Schritt 1, Bild 1 von 2 Samsung Epic 4G Touch Battery Replacement, Rear Case: Schritt 1, Bild 2 von 2
    • Insert a plastic opening tool, or your fingernail, into the opening near the left side of the headphone jack.
    • Pry the opening tool downward to pop the rear case from its clips securing it to the the midframe.
  2. Samsung Epic 4G Touch Battery Replacement: Schritt 2, Bild 1 von 2 Samsung Epic 4G Touch Battery Replacement: Schritt 2, Bild 2 von 2
    • Lift and remove the rear case.
  3. Samsung Epic 4G Touch Battery Replacement, Battery: Schritt 3, Bild 1 von 2 Samsung Epic 4G Touch Battery Replacement, Battery: Schritt 3, Bild 2 von 2
    • Wedge a plastic opening tool into the crevice between the battery and midframe located near the bottom left corner.
    • Push the plastic opening tool downward to pry the battery up from its housing.
  4. Samsung Epic 4G Touch Battery Replacement: Schritt 4, Bild 1 von 2 Samsung Epic 4G Touch Battery Replacement: Schritt 4, Bild 2 von 2
    • Lift and remove the battery from the midframe.
Abschluss
10 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
i just reacently got my phone and I don't know whats happening to it. it keeps turning itself off. iv factory reset it 2 times. should I replace the phone or just the battery. I have a Samsung galaxy s II. (sprint)
gamerzzz - Antwort
I have an samsung galaxy s2 gsm unlocked and my battery wont stay charge and sometimes when its plugged in a charger it decreases instead of increasing and if it does charges it decrease fast what shall i do shall i get a new battery or replace the phone
ianasims - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 12
Letzte 30 Tage: 17
Insgesamt: 9,717
