Einleitung
Prereq to remove the Upper Display Assembly Bracket.
Was du brauchst
Use the flat end of a spudger to disconnect the headphone jack/earpiece speaker assembly cable connector.
Remove the two 3 mm Phillips #00 screws securing the upper display assembly bracket.
Use a pair of tweezers, or your fingers, to remove the upper display assembly bracket.
Fast fertig!
Abschluss
