Zum Hauptinhalt wechseln
Was du brauchst
Dieser Teardown ist keine Reparaturanleitung. Um dein LG Rumor (LX260) zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. LG Rumor LX260 Teardown, LG Rumor LX260 Teardown: Schritt 1, Bild 1 von 3 LG Rumor LX260 Teardown, LG Rumor LX260 Teardown: Schritt 1, Bild 2 von 3 LG Rumor LX260 Teardown, LG Rumor LX260 Teardown: Schritt 1, Bild 3 von 3
  2. LG Rumor LX260 Teardown: Schritt 2, Bild 1 von 2 LG Rumor LX260 Teardown: Schritt 2, Bild 2 von 2
    • Now, start by removing the battery, it is attatched to the back cover, and can be removed by pushing the tab back.
  3. LG Rumor LX260 Teardown: Schritt 3, Bild 1 von 2 LG Rumor LX260 Teardown: Schritt 3, Bild 2 von 2
    • Remove these 6 phillips screws:
    • These two top screws are covered by rubber plugs that can be removed by a small flathead screwdrivew, or a fingernail.
  4. LG Rumor LX260 Teardown: Schritt 4, Bild 1 von 2 LG Rumor LX260 Teardown: Schritt 4, Bild 2 von 2
    • Remove the covers for the Headphone, Micro SD and Charging connectors, but be careful, they are still connected, pull them only as far as they will come out!
  5. LG Rumor LX260 Teardown: Schritt 5, Bild 1 von 1
    • You should now be able to lift the back cover off, it is held on with a mild adhesive, so a little force may be required the first time.
  6. LG Rumor LX260 Teardown: Schritt 6, Bild 1 von 2 LG Rumor LX260 Teardown: Schritt 6, Bild 2 von 2
    • Remove the "Camera" and "Volume" buttons.
    • Be careful, the actual buttons, ane attatched to the locic board with a very thin ribbon cable, only remove the button covers.
  7. LG Rumor LX260 Teardown: Schritt 7, Bild 1 von 2 LG Rumor LX260 Teardown: Schritt 7, Bild 2 von 2
    • Remove these two phillips screws:
    • Now, removed the highlighted clips (2nd Picture) this will free the logic board.
    • I recomend starting with this one, and once this tab is free, you can just slide it around the other clips.
  8. LG Rumor LX260 Teardown: Schritt 8, Bild 1 von 2 LG Rumor LX260 Teardown: Schritt 8, Bild 2 von 2
    • Now, pivot the logic board up, to reveal the LCD/Numeric Keypad Cable, remove this with a spudger or flathead screwdriver.
    • You should now be able to remove the logic board.
  9. LG Rumor LX260 Teardown: Schritt 9, Bild 1 von 1
    • The Logic board:
    • The CPU is a Qualcomm MSM6100 ARM Processor
    • The RAM, it is manufactured by Hynix
    • The Camera 1.3MP, not bad
    • The SD Card Slot:
    • Speaker [Speakerphone]
    • Headphone Jack:
    • Battery Contacts:
  10. LG Rumor LX260 Teardown: Schritt 10, Bild 1 von 3 LG Rumor LX260 Teardown: Schritt 10, Bild 2 von 3 LG Rumor LX260 Teardown: Schritt 10, Bild 3 von 3
    • The keypad cover is easily replacable, and simply lifts out.
  11. LG Rumor LX260 Teardown: Schritt 11, Bild 1 von 3 LG Rumor LX260 Teardown: Schritt 11, Bild 2 von 3 LG Rumor LX260 Teardown: Schritt 11, Bild 3 von 3
    • Seperating the phone sliding assembly:
    • Remove these 4 Phillips screws:
    • Now, lift it off, threading the Screen/Number Pad Cable Through the hole.
  12. LG Rumor LX260 Teardown: Schritt 12, Bild 1 von 3 LG Rumor LX260 Teardown: Schritt 12, Bild 2 von 3 LG Rumor LX260 Teardown: Schritt 12, Bild 3 von 3
    • Remove these phillips screws:
    • To remove all 6, you will need to slide the sliding assembly to get to the center two screws.
    • Now, using a spudger, or flathead screwdriver, seperate the two halves of the assembly, threading the data cable through it's hole.
    • This may take a little force since a mild adhesive is applied around the rim.
  13. LG Rumor LX260 Teardown: Schritt 13, Bild 1 von 2 LG Rumor LX260 Teardown: Schritt 13, Bild 2 von 2
    • Now, detatch the data cable from the board using a spudger, be careful, it is a fragile connector, and you should lift it straight up.
    • Now, remove this piece of clear yellow-tinted tape covering the connectors.
  14. LG Rumor LX260 Teardown: Schritt 14, Bild 1 von 2 LG Rumor LX260 Teardown: Schritt 14, Bild 2 von 2
    • You will now need to remove this piece of gold-mesh tape.
    • BE CAREFUL WHEN REMOVING THIS, SINCE IT PROVIDES A GROUND, AND WILL NEED TO BE PUT BACK IN UPON RE-ASSEMBLY!
  15. LG Rumor LX260 Teardown: Schritt 15, Bild 1 von 3 LG Rumor LX260 Teardown: Schritt 15, Bild 2 von 3 LG Rumor LX260 Teardown: Schritt 15, Bild 3 von 3
    • Now, flip this tab up, towards the bottom of the phone, and remove the speaker/side-button cable.
    • Now, slowly lift the cable up, minding the adhesive on the back.
    • When you come to the buttons, be especially careful, and when you get to the speaker, use a flathead screwdriver, and pop the speaker out.
  16. LG Rumor LX260 Teardown: Schritt 16, Bild 1 von 3 LG Rumor LX260 Teardown: Schritt 16, Bild 2 von 3 LG Rumor LX260 Teardown: Schritt 16, Bild 3 von 3
    • Using a spudger or flathead screwdriver, lift this tab up, to release the display cable.
    • Now, guide the cable out of the connector, until you can set it on top of the assembly.
  17. LG Rumor LX260 Teardown: Schritt 17, Bild 1 von 3 LG Rumor LX260 Teardown: Schritt 17, Bild 2 von 3 LG Rumor LX260 Teardown: Schritt 17, Bild 3 von 3
    • Now, to remove the board, use a flathead screwdriver or spudger to clear the tab on one side, then remove the board completly, similarly to the logic board.
  18. LG Rumor LX260 Teardown: Schritt 18, Bild 1 von 2 LG Rumor LX260 Teardown: Schritt 18, Bild 2 von 2
    • You can now lift the keypad cover off, just like we did earlier with the alphabetical keyboard.
  19. LG Rumor LX260 Teardown: Schritt 19, Bild 1 von 2 LG Rumor LX260 Teardown: Schritt 19, Bild 2 von 2
    • Unfortionatly, the LCD panel is held in place by a heavy adhesive, and removal will almost certianly crack the screen, so only remove it if you are replacing the screen.
  20. LG Rumor LX260 Teardown: Schritt 20, Bild 1 von 1
    • Group Shot!
Chris Green
36.978 Reputation
49 Anleitungen geschrieben
Master Techs Mitglied von Master Techs
Community
322 Mitglieder
2.532 Anleitungen geschrieben
2 Kommentare
I'd recommend not opening the screen bit in any way shap or form.
qwerty keyboard - Antwort
I tore down an AX260. Tear down is identical. I removed the screen, too. I heated the entire glass with a variable heat gun set to approximately 140F. I monitored the temperature of the glass with a non contact infrared thermometer. At just under 140F the screen separated from the glass on three sides. I hinged the screen and applied the heat to the remaining adhesive. As it warmed the adhesive disengaged from the screen intact. The adhesive acts like a sticky foam. Screen was clean with no adhesive residue and would be easy replace glass or screen at that point.
Thank you for a very nice tear down guide.
jharden2 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 13
Insgesamt: 51,927
