Zum Hauptinhalt wechseln
TomTom XXL 540 Battery Replacement
Was du brauchst
  1. TomTom XXL 540 Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Peel back the sticker on the bottom of the device to reveal the two screws.
  2. TomTom XXL 540 Battery Replacement: Schritt 2, Bild 1 von 1
    • Unscrew the two T5 Torx screws.
  3. TomTom XXL 540 Battery Replacement: Schritt 3, Bild 1 von 1
    • Wedge the flat head of the screwdriver into the edge of the device. Gently lift the screen from the cover.
  4. TomTom XXL 540 Battery Replacement: Schritt 4, Bild 1 von 1
    • Release the yellow ribbon cable.
  5. TomTom XXL 540 Battery Replacement: Schritt 5, Bild 1 von 1
    • Identify the green motherboard. Unscrew the three screws holding the board in place.
  6. TomTom XXL 540 Battery Replacement: Schritt 6, Bild 1 von 1
    • Remove the motherboard from the back plate.
  7. TomTom XXL 540 Battery Replacement: Schritt 7, Bild 1 von 1
    • Unplug the battery from the board.
  8. TomTom XXL 540 Battery Replacement: Schritt 8, Bild 1 von 1
    • Plug the new battery into the white receptacle on the green motherboard.
  9. TomTom XXL 540 Battery Replacement: Schritt 9, Bild 1 von 1
    • Transfer the green motherboard back into the back plate and secure it with the 3 screws.
  10. TomTom XXL 540 Battery Replacement: Schritt 10, Bild 1 von 1
    • Reconnect the yellow ribbon cable and connect the screen and back plate back together.
  11. TomTom XXL 540 Battery Replacement: Schritt 11, Bild 1 von 1
    • Insert the t-5 screws and tighten to secure.
  12. TomTom XXL 540 Battery Replacement: Schritt 12, Bild 1 von 1
    • Replace the label to cover the screws.
Abschluss
5 weitere Nutzer:innen haben diese Anleitung absolviert.
Mike Sollars
519 Reputation
3 Anleitungen geschrieben
WRI115, Team 1-1, Ruszkiewicz Spring 2013 Mitglied von WRI115, Team 1-1, Ruszkiewicz Spring 2013
WRI115-RUSZKIEWICZ-S13S1G1
4 Mitglieder
6 Anleitungen geschrieben
Ein Kommentar
Very similar for the 4FL60 and 6000, except in :
Step 1 the screws are visible without removing any stickers
Step 4 hint: to release the ribbon, each end of the white bar has a self-sprung clip to ease away, try not to break them. And for the models above there is a small cable plug to unclip
Step 5 there are 5 screws holding the motherboard
Step 6 it is necessary to unclip plugs for the battery and speaker leads
and vice versa for reassembly
Jim Shaw - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 15
Insgesamt: 4,586
