Zum Hauptinhalt wechseln
Ricoh YF-20 Super Lens Replacement
Was du brauchst
  1. Ricoh YF-20 Super Lens Replacement, Front Cover: Schritt 1, Bild 1 von 2 Ricoh YF-20 Super Lens Replacement, Front Cover: Schritt 1, Bild 2 von 2
    • Use the screwdriver to unscrew the indicated screws from the left, right, bottom, and back sides of the camera.
  2. Ricoh YF-20 Super Lens Replacement: Schritt 2, Bild 1 von 3 Ricoh YF-20 Super Lens Replacement: Schritt 2, Bild 2 von 3 Ricoh YF-20 Super Lens Replacement: Schritt 2, Bild 3 von 3
    • Loosen the back cover from both the left and the right sides of the camera. Take off the back cover.
    • The lid of the battery compartment may fall off because it is not attached to anything.
  3. Ricoh YF-20 Super Lens Replacement: Schritt 3, Bild 1 von 3 Ricoh YF-20 Super Lens Replacement: Schritt 3, Bild 2 von 3 Ricoh YF-20 Super Lens Replacement: Schritt 3, Bild 3 von 3
    • Open the film compartment.
    • Press your finger on top of the grey latch on the left side of the camera.
  4. Ricoh YF-20 Super Lens Replacement: Schritt 4, Bild 1 von 3 Ricoh YF-20 Super Lens Replacement: Schritt 4, Bild 2 von 3 Ricoh YF-20 Super Lens Replacement: Schritt 4, Bild 3 von 3
    • Removing the film compartment door is optional. However, it may aid maneuverability in future steps.
    • Use a thin object like a toothpick or a small screwdriver to push down on the metal pin holding the film compartment door in place.
    • Use your fingers to completely remove the metal pin.
    • Remove the film compartment door.
  5. Ricoh YF-20 Super Lens Replacement: Schritt 5, Bild 1 von 2 Ricoh YF-20 Super Lens Replacement: Schritt 5, Bild 2 von 2
    • Use a thin shaft screwdriver and unscrew the two indicated screws within the film compartment.
  6. Ricoh YF-20 Super Lens Replacement: Schritt 6, Bild 1 von 3 Ricoh YF-20 Super Lens Replacement: Schritt 6, Bild 2 von 3 Ricoh YF-20 Super Lens Replacement: Schritt 6, Bild 3 von 3
    • Loosen the front cover from the left and right sides of the camera.
    • Take off the front cover.
  7. Ricoh YF-20 Super Lens Replacement, Lens: Schritt 7, Bild 1 von 3 Ricoh YF-20 Super Lens Replacement, Lens: Schritt 7, Bild 2 von 3 Ricoh YF-20 Super Lens Replacement, Lens: Schritt 7, Bild 3 von 3
    • The lens is only attached to the main camera body. Set the front and back covers aside.
    • Unscrew three screws from the outermost plastic plate covering the lens.
    • After the screws are removed, the outermost plate can be removed.
  8. Ricoh YF-20 Super Lens Replacement: Schritt 8, Bild 1 von 3 Ricoh YF-20 Super Lens Replacement: Schritt 8, Bild 2 von 3 Ricoh YF-20 Super Lens Replacement: Schritt 8, Bild 3 von 3
    • Remove the ring shaped metal brace.
    • Using fingers or tweezers, remove the lens from the camera.
Abschluss
Eric Dazet
352 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 6-21, Amido Spring 2012 Mitglied von Cal Poly, Team 6-21, Amido Spring 2012
CPSU-AMIDO-S12S6G21
4 Mitglieder
18 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 646
