Zum Hauptinhalt wechseln
Was du brauchst
Dieser Teardown ist keine Reparaturanleitung. Um dein Nintendo GameCube zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. Nintendo GameCube Teardown, Nintendo GameCube Teardown: Schritt 1, Bild 1 von 3 Nintendo GameCube Teardown, Nintendo GameCube Teardown: Schritt 1, Bild 2 von 3 Nintendo GameCube Teardown, Nintendo GameCube Teardown: Schritt 1, Bild 3 von 3
    • Flip the unit upside down and remove the screws sitting in the four deep holes in the corners using a 4.5mm gamebit driver. Don't remove the enclosure yet!
    • Turn the device right side up again, and now lift the top case off. It'll come up easily.
  2. Nintendo GameCube Teardown: Schritt 2, Bild 1 von 3 Nintendo GameCube Teardown: Schritt 2, Bild 2 von 3 Nintendo GameCube Teardown: Schritt 2, Bild 3 von 3
    • Unsnap the controller port cover and the rearmost I/O-cover by unsnapping the two snaps on the sides of each cover. Don't remove the controller panel yet.
    • Then remove the heatsinks of the memory card slots (necessary step).
  3. Nintendo GameCube Teardown: Schritt 3, Bild 1 von 3 Nintendo GameCube Teardown: Schritt 3, Bild 2 von 3 Nintendo GameCube Teardown: Schritt 3, Bild 3 von 3
    • Now start removing the 'normal' Phillips #2 screws.
    • Start by removing the fan assembly.
    • then unscrew the 12 visible screws on the edging of the now not so cube-shaped GameCube.
  4. Nintendo GameCube Teardown: Schritt 4, Bild 1 von 1
    • Now you can lift the drive assembly up. You maybe have to loosen it a bit with a screwdriver or a heavy duty spudger.
    • The mainboard is now visible.
  5. Nintendo GameCube Teardown: Schritt 5, Bild 1 von 2 Nintendo GameCube Teardown: Schritt 5, Bild 2 von 2
    • Now remove the heatsink. Unscrew the six screws holding it.
    • Now use anything flat and durable to carefully lift up the heatsink by putting it under the aluminium and using it gently as a lever.
  6. Nintendo GameCube Teardown: Schritt 6, Bild 1 von 2 Nintendo GameCube Teardown: Schritt 6, Bild 2 von 2
    • If there are thermal pads remaining on the processors and/or ram chips, remove them with a plastic spudger.
    • Now disconnect the controller port panel connector by lifting and jiggling it carefully. It should come off easily.
  7. Nintendo GameCube Teardown: Schritt 7, Bild 1 von 2 Nintendo GameCube Teardown: Schritt 7, Bild 2 von 2
    • 24 MB MoSys 1T-SRAM
    • ATI 'Flipper' GPU, 162 MHz with 3 MB 1T-SRAM embedded within the die
    • IBM 'Gekko' CPU, 486 MHz (PowerPC 750CXe-based core)
    • Connectors (2nd pic):
    • 'Hi Speed Port'
    • 'Serial Port 1'
    • 'Serial Port 2'
  8. Nintendo GameCube Teardown: Schritt 8, Bild 1 von 3 Nintendo GameCube Teardown: Schritt 8, Bild 2 von 3 Nintendo GameCube Teardown: Schritt 8, Bild 3 von 3
    • If you lift the mainboard up, you'll see a metal plate, probably for EMI-protection. Remove the two screws holding it and you have access to the internal power supply.
Thomas J
409 Reputation
1 Anleitung geschrieben
13 Kommentare
Great teardown Thomas!
Miroslav Djuric - Antwort
Thanks!
Thomas J - Antwort
WOW! Great work, Nintendo stuff is hard to open!
Mc128k - Antwort
Thank you! Everything beyond Triwing requires creativity.
Thomas J - Antwort
Will I need to reapply the thermal paste?
http://i.imgur.com/Q6antAn.jpg
Calvin Hall - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 34
Letzte 7 Tage: 262
Letzte 30 Tage: 1,257
Insgesamt: 135,912
