Zum Hauptinhalt wechseln
PSP 1000 Front Casing Replacement
Was du brauchst
  1. PSP 1000 Front Casing Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn the PSP over so its back is facing you.
  2. PSP 1000 Front Casing Replacement: Schritt 2, Bild 1 von 2 PSP 1000 Front Casing Replacement: Schritt 2, Bild 2 von 2
    • Locate the battery casing button on the rear-left side of the PSP.
    • Press down the button and remove the battery cover.
  3. PSP 1000 Front Casing Replacement: Schritt 3, Bild 1 von 2 PSP 1000 Front Casing Replacement: Schritt 3, Bild 2 von 2
    • Using your finger, remove the battery upwards from the system as shown.
  4. PSP 1000 Front Casing Replacement, Front Casing: Schritt 4, Bild 1 von 2 PSP 1000 Front Casing Replacement, Front Casing: Schritt 4, Bild 2 von 2
    • Remove the four screws shown with a Phillips #00 screwdriver.
    • You will have to peel back the guarantee sticker to access the screw on the lower left.
  5. PSP 1000 Front Casing Replacement: Schritt 5, Bild 1 von 1
    • Remove the screw from the bottom side of the PSP. Keep it separated from the rest of the screws.
    • Remove screws from back righthand side within the holes.
  6. PSP 1000 Front Casing Replacement: Schritt 6, Bild 1 von 2 PSP 1000 Front Casing Replacement: Schritt 6, Bild 2 von 2
    • Gently separate the outer plastic casing from the rest of the system as shown.
Abschluss
33 weitere Nutzer:innen haben diese Anleitung absolviert.
Henry Lee
794 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 5-6, Forte Winter 2010 Mitglied von Cal Poly, Team 5-6, Forte Winter 2010
CPSU-FORTE-W10S5G6
5 Mitglieder
22 Anleitungen geschrieben
3 Kommentare
Thank you! Awesome help!
Jay Vee - Antwort
My psp is updating then psp is fallen down and battery comeout so please help me please thank you
Bye
National Nazeer - Antwort
i also made a video on this for anyone who needs to do it that way.
https://www.youtube.com/watch?v=EIAaJyIx...
DAS Repair - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 10
Letzte 7 Tage: 63
Letzte 30 Tage: 329
Insgesamt: 40,352
