Zum Hauptinhalt wechseln
Tungsten E Disassembly
Was du brauchst
  1. Tungsten E Disassembly, Tungsten E Disassembly: Schritt 1, Bild 1 von 2 Tungsten E Disassembly, Tungsten E Disassembly: Schritt 1, Bild 2 von 2
    • Remove the stylus and SD card.
    • Using a T5 torx screwdriver, remove all 4 back panel screws.
    • The screws are small and can be lost easily. Be sure to place them in a secure area.
  2. Tungsten E Disassembly: Schritt 2, Bild 1 von 3 Tungsten E Disassembly: Schritt 2, Bild 2 von 3 Tungsten E Disassembly: Schritt 2, Bild 3 von 3
    • Insert a plastic opening tool under the USB and power input slots.
    • Slide the plastic opener along the seam and gently pry the cover from the PDA body to remove the cover completely.
  3. Tungsten E Disassembly: Schritt 3, Bild 1 von 2 Tungsten E Disassembly: Schritt 3, Bild 2 von 2
    • Your device may not have a screen protector. If not, you can move on to step four.
    • Remove the screen protector by lifting the hinge out of the plastic housing.
    • Remove the top cover by gently pulling it away from the device with a plastic opening tool or your fingers.
  4. Tungsten E Disassembly: Schritt 4, Bild 1 von 2 Tungsten E Disassembly: Schritt 4, Bild 2 von 2
    • Carefully remove motherboard from the standoffs without damaging the LCD flex connector.
    • Using a spudger, unlock both sides of the flex connector block by pushing down.
    • Remove motherboard completely.
    • Metal washers may pop out of the device during this step
  5. Tungsten E Disassembly: Schritt 5, Bild 1 von 3 Tungsten E Disassembly: Schritt 5, Bild 2 von 3 Tungsten E Disassembly: Schritt 5, Bild 3 von 3
    • Remove buttons using fingers.
    • Gently flex frame to release screen from plastic frame.
    • Lift out screen.
  6. Tungsten E Disassembly: Schritt 6, Bild 1 von 1
    • Congratulations! You have successfully taken apart a Palm Tungsten E.
Abschluss
Kevin Hom
103 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 13-22, Maness Winter 2010 Mitglied von Cal Poly, Team 13-22, Maness Winter 2010
CPSU-MANESS-W10S13G22
4 Mitglieder
4 Anleitungen geschrieben
Ein Kommentar
How does one unplug the battery?
dlcatftwin - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 10
Insgesamt: 7,786
