Zum Hauptinhalt wechseln
Motorola V325 Battery Replacement
  1. Motorola V325 Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Flip the phone over so that the back is visible.
    • Push down on the silver button using your fingernail or thumbnail. Push down all the way until the button stops.
  2. Motorola V325 Battery Replacement: Schritt 2, Bild 1 von 3 Motorola V325 Battery Replacement: Schritt 2, Bild 2 von 3 Motorola V325 Battery Replacement: Schritt 2, Bild 3 von 3
    • While holding down the silver button, simultaneously pull downward on the rear cover, then lift it off to reveal the battery.
    • This will only take a moment to do.
  3. Motorola V325 Battery Replacement: Schritt 3, Bild 1 von 3 Motorola V325 Battery Replacement: Schritt 3, Bild 2 von 3 Motorola V325 Battery Replacement: Schritt 3, Bild 3 von 3
    • Using your thumbnail and fingernail, grip the battery where indicated as "pull here" and lift the battery upward, starting at that side.
    • Remove the battery completely by lifting it straight out of the phone.
  4. Motorola V325 Battery Replacement: Schritt 4, Bild 1 von 1
    • When replacing the battery, ensure that the side that has the "pull here" arrows goes toward the bottom of the phone. Place the side of the battery with the metallic contacts in toward the inside of the phone, making a full connection with the contacts within the phone (shown in the red rectangle).
Abschluss
Adrian Doan
22 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 4-15, Forte Winter 2010 Mitglied von Cal Poly, Team 4-15, Forte Winter 2010
CPSU-FORTE-W10S4G15
5 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 17
Insgesamt: 2,621
