Zum Hauptinhalt wechseln
Canon PowerShot S500 Front and Rear Casing Replacement
Was du brauchst
  1. Canon PowerShot S500 Front and Rear Casing  Replacement, Front and Rear Casing : Schritt 1, Bild 1 von 2 Canon PowerShot S500 Front and Rear Casing  Replacement, Front and Rear Casing : Schritt 1, Bild 2 von 2
    • Unscrew five Phillips screws using a #0 Phillips screwdriver.
    • One screw is on upper right corner of the back panel.
    • The other four screws are on the bottom of the camera.
  2. Canon PowerShot S500 Front and Rear Casing  Replacement: Schritt 2, Bild 1 von 1
    • Open the memory card cover by moving the slide switch toward the top end of of the camera.
    • Remove the memory card from the slot.
  3. Canon PowerShot S500 Front and Rear Casing  Replacement: Schritt 3, Bild 1 von 1
    • Remove the rear cover from the rest of the camera.
    • This may require gentle rocking of the case to free it.
  4. Canon PowerShot S500 Front and Rear Casing  Replacement: Schritt 4, Bild 1 von 2 Canon PowerShot S500 Front and Rear Casing  Replacement: Schritt 4, Bild 2 von 2
    • Unscrew the four Phillips screws from the side of the casing and one screw from the bottom using a #0 Phillips screwdriver.
  5. Canon PowerShot S500 Front and Rear Casing  Replacement: Schritt 5, Bild 1 von 1
    • Free the front cover from the rest of the camera.
    • The cover may require gentle rocking to remove.
Ziellinie
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Nathan Balcom
81 Reputation
8 Anleitungen geschrieben
Cal Poly, Team 16-28, Maness Winter 2010 Mitglied von Cal Poly, Team 16-28, Maness Winter 2010
CPSU-MANESS-W10S16G28
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 1,603
