Zum Hauptinhalt wechseln
Palm IIIx Front Button Cluster Replacement
Was du brauchst
  1. Palm IIIx Front Button Cluster Replacement, Battery: Schritt 1, Bild 1 von 1
    • Place the Palm IIIx face down on a flat surface.
  2. Palm IIIx Front Button Cluster Replacement: Schritt 2, Bild 1 von 1
    • Push down and lift up the battery cover to remove it.
  3. Palm IIIx Front Button Cluster Replacement: Schritt 3, Bild 1 von 1
    • Remove the old batteries one at a time.
  4. Palm IIIx Front Button Cluster Replacement, Front Button Cluster: Schritt 4, Bild 1 von 1
    • Using a Phillips #00 screwdriver, remove the four screws that hold the back cover in place.
  5. Palm IIIx Front Button Cluster Replacement: Schritt 5, Bild 1 von 1
    • Hold the device on its side, positioning your hands as shown.
    • Remove the back cover by pushing in with your thumbs and pulling outward with the rest of your fingers
  6. Palm IIIx Front Button Cluster Replacement: Schritt 6, Bild 1 von 1
    • Hold the screen and front cover in a vertical position, facing the screen inward, as shown.
    • Position your hands so you can push the screen outward with your thumbs.
    • Remove the front cover by gently pushing outward with your thumbs. Use your index fingers to pull back on the front cover.
  7. Palm IIIx Front Button Cluster Replacement: Schritt 7, Bild 1 von 1
    • Remove cluster by pulling on the rubber backing.
    • Clean, repair, and/or replace as neccessary.
Abschluss
David Haskell
44 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 14-43, Regan Winter 2010 Mitglied von Cal Poly, Team 14-43, Regan Winter 2010
CPSU-REGAN-W10S14G43
4 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 11
Insgesamt: 1,343
