Zum Hauptinhalt wechseln
Acer Chromebook C710-2847 Back Cover Replacement
Was du brauchst
  1. Acer Chromebook C710-2847 Back Cover Replacement, Battery: Schritt 1, Bild 1 von 2 Acer Chromebook C710-2847 Back Cover Replacement, Battery: Schritt 1, Bild 2 von 2
    • Place the laptop on a flat surface with the bottom side facing up.
    • Place the tip of a spudger or finger into the hole on the battery release slider.
  2. Acer Chromebook C710-2847 Back Cover Replacement: Schritt 2, Bild 1 von 2 Acer Chromebook C710-2847 Back Cover Replacement: Schritt 2, Bild 2 von 2
    • Use the spudger to move the slider to the right and hold it there.
    • With the slider held, use your other hand to pull the battery back away from the laptop.
  3. Acer Chromebook C710-2847 Back Cover Replacement, Acer Chromebook C710-2847 Back Cover Replacement: Schritt 3, Bild 1 von 1
    • This step will void your device warranty.
    • Use the screwdriver to pierce the warranty sticker.
    • Unscrew and remove the #0 6mm Phillips screw and set it aside.
  4. Acer Chromebook C710-2847 Back Cover Replacement: Schritt 4, Bild 1 von 2 Acer Chromebook C710-2847 Back Cover Replacement: Schritt 4, Bild 2 von 2
    • Slide the back panel towards you. The best spots to place your fingers are on the bumpers.
    • Lift on the front edge to remove the panel.
Abschluss
9 weitere Nutzer:innen haben diese Anleitung absolviert.
Bradley Pavy
1.257 Reputation
6 Anleitungen geschrieben
Cal Poly, Team 13-3, Forte Fall 2013 Mitglied von Cal Poly, Team 13-3, Forte Fall 2013
CPSU-FORTE-F13S13G3
5 Mitglieder
14 Anleitungen geschrieben
Ein Kommentar
Once you have the back cover off, you can insert aluminum foil into a tiny connector, which will allow you to flash the BIOS and boot any operating system, not just ChromeOS. Using this method, I completely wiped ChromeOS from my C710 and installed Ubuntu 16.04 LTS. Definitely worth it, because now I have a sub-$300 Linux netbook with a removable battery, standard keyboard with CAPS lock (most Chromebooks don't), and no ugly Windows key.
Uncle Happy - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 22
Insgesamt: 6,308
