Zum Hauptinhalt wechseln
Nokia 3360 Cover Plate Replacement
  1. Nokia 3360 Cover Plate Replacement, Battery: Schritt 1, Bild 1 von 1
    • Press down on the back of the phone with your thumb. Then slide the back plate upward toward the top of the phone.
    • Lift the back plate off the phone.
  2. Nokia 3360 Cover Plate Replacement: Schritt 2, Bild 1 von 2 Nokia 3360 Cover Plate Replacement: Schritt 2, Bild 2 von 2
    • To release the battery, press the two tabs that are located directly above the battery towards the top of the phone at the same time.
  3. Nokia 3360 Cover Plate Replacement: Schritt 3, Bild 1 von 2 Nokia 3360 Cover Plate Replacement: Schritt 3, Bild 2 von 2
    • Lift the battery out of the phone.
    • Note: Upon reassembly of the phone refer to second picture. The bottom of the battery with three square openings should line up with the prongs sticking out of the phone.
  4. Nokia 3360 Cover Plate Replacement, Cover Plate: Schritt 4, Bild 1 von 2 Nokia 3360 Cover Plate Replacement, Cover Plate: Schritt 4, Bild 2 von 2
    • Use finger nails of your thumbs to gently pull apart the face plate.
    • While the face plate is pulled apart, use index fingers to pull inner case towards you.
    • Separate faceplate and inner case.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Kirk Gonzalez
223 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 8-39, Regan Winter 2010 Mitglied von Cal Poly, Team 8-39, Regan Winter 2010
CPSU-REGAN-W10S8G39
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 10
Insgesamt: 2,668
