Zum Hauptinhalt wechseln
Palm Treo 600 Screen Replacement
Was du brauchst
  1. Palm Treo 600 Screen Replacement, Back Case: Schritt 1, Bild 1 von 1
    • On the back of the device, locate the 3 rubber plugs, and use a plastic spudger to remove them.
  2. Palm Treo 600 Screen Replacement: Schritt 2, Bild 1 von 2 Palm Treo 600 Screen Replacement: Schritt 2, Bild 2 von 2
    • Use the T6 Torx Screwdriver to remove all 4 screws.
    • You have to first remove the Stylus to access the 4th screw.
  3. Palm Treo 600 Screen Replacement: Schritt 3, Bild 1 von 2 Palm Treo 600 Screen Replacement: Schritt 3, Bild 2 von 2
    • Using a plastic opening tool, carefully separate the front and back cases.
    • Note: The antenna will detach from the phone.
  4. Palm Treo 600 Screen Replacement, Front Case: Schritt 4, Bild 1 von 2 Palm Treo 600 Screen Replacement, Front Case: Schritt 4, Bild 2 von 2
    • Using a T6 Torx Screwdriver, remove the two screws.
    • The motherboard will now be loose from the front case.
  5. Palm Treo 600 Screen Replacement, Screen: Schritt 5, Bild 1 von 1
    • The screen is connected to the phone with an orange data cable.
    • Slide the spudger as close to the connection as possible.
    • Gently pull the spudger up and the cable should come out of the socket.
  6. Palm Treo 600 Screen Replacement: Schritt 6, Bild 1 von 2 Palm Treo 600 Screen Replacement: Schritt 6, Bild 2 von 2
    • Once the cable is unplugged, you can remove the screen from the body.
Abschluss
Cal Poly, Team 13-23, Maness Winter 2010 Mitglied von Cal Poly, Team 13-23, Maness Winter 2010
CPSU-MANESS-W10S13G23
4 Mitglieder
16 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 11
Insgesamt: 2,189
