Zum Hauptinhalt wechseln
Sprint Sanyo RL-4920 Speaker Replacement
Was du brauchst
  1. Sprint Sanyo RL-4920 Speaker Replacement, Back of Phone: Schritt 1, Bild 1 von 1
    • Flip the phone over so that the screen is facing down.
  2. Sprint Sanyo RL-4920 Speaker Replacement, Remove Battery Pack: Schritt 2, Bild 1 von 2 Sprint Sanyo RL-4920 Speaker Replacement, Remove Battery Pack: Schritt 2, Bild 2 von 2
    • Push the gray lever up towards the top of the phone.
    • Pull up on the battery pack and completely separate it from the phone.
  3. Sprint Sanyo RL-4920 Speaker Replacement, Screws: Schritt 3, Bild 1 von 2 Sprint Sanyo RL-4920 Speaker Replacement, Screws: Schritt 3, Bild 2 von 2
    • Locate the five screws around the back casing.
    • Use a three-prong screw bit to remove all five screws.
  4. Sprint Sanyo RL-4920 Speaker Replacement, Separate Cases: Schritt 4, Bild 1 von 1
    • Use the plastic opening tool and slide it around the phone to pull apart the front and back casing.
  5. Sprint Sanyo RL-4920 Speaker Replacement, Separate Cases: Schritt 5, Bild 1 von 1
    • Separate the two cases.
  6. Sprint Sanyo RL-4920 Speaker Replacement, The Front Case: Schritt 6, Bild 1 von 1
    • Use the plastic opening tool to remove the motherboard from the front case.
  7. Sprint Sanyo RL-4920 Speaker Replacement, Screws: Schritt 7, Bild 1 von 2 Sprint Sanyo RL-4920 Speaker Replacement, Screws: Schritt 7, Bild 2 von 2
    • Locate the three screws securing the speaker.
    • Use a Phillips-head screw bit to unscrew the screws
  8. Sprint Sanyo RL-4920 Speaker Replacement, Replace Speaker: Schritt 8, Bild 1 von 1
    • Remove the speaker.
    • Replace with new speaker.
    • Secure new speaker with screws and reassemble phone.
Abschluss
Austin Shores
301 Reputation
3 Anleitungen geschrieben
Clemson, Team 13-5, Benson Fall 2013 Mitglied von Clemson, Team 13-5, Benson Fall 2013
CLEM-BENSON-F13S13G5
3 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 7
Letzte 30 Tage: 11
Insgesamt: 163
