Einleitung
Before being able to access the inner parts of the device, it is necessary to remove the plastic outer case. This can easily be done in a few simple steps.
Was du brauchst
Begin by placing the camera flat against a surface and remove the nine (9) black screws. Each screw is of the same length and can be used interchangeably
Once the outer casings have been removed, the silver side trim should come loose from the camera.
Place the camera with the lens facing down. Use the plastic opening tool to pry off the side panel with the USB plug.
Place the camera with the lens facing down. Use the phillips head screwdriver to remove the silver screw in the corner near the photo capture button.
Flip the camera over. Use the plastic opening tool to detach the black clip near the capture button.
Grasp the top cover and gently remove it from the camera body.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
