Zum Hauptinhalt wechseln
HP iPAQ H2200 Joypad Replacement
Was du brauchst
  1. HP iPAQ H2200 Joypad Replacement, Battery: Schritt 1, Bild 1 von 1
    • Press and slide the battery cover tab to remove battery cover.
  2. HP iPAQ H2200 Joypad Replacement: Schritt 2, Bild 1 von 2 HP iPAQ H2200 Joypad Replacement: Schritt 2, Bild 2 von 2
    • Pull on the black tab to lift the battery out of the battery compartment.
  3. HP iPAQ H2200 Joypad Replacement, Main Board: Schritt 3, Bild 1 von 1
    • Remove the stylus by sliding it out of the slot.
  4. HP iPAQ H2200 Joypad Replacement: Schritt 4, Bild 1 von 1
    • Remove the CF card by sliding it out of the slot at the top of the device.
  5. HP iPAQ H2200 Joypad Replacement: Schritt 5, Bild 1 von 1
    • Press down and push the black side strips toward the top of the device to remove them.
  6. HP iPAQ H2200 Joypad Replacement: Schritt 6, Bild 1 von 3 HP iPAQ H2200 Joypad Replacement: Schritt 6, Bild 2 von 3 HP iPAQ H2200 Joypad Replacement: Schritt 6, Bild 3 von 3
    • Using the T5 Torx screwdriver, remove all six screws on the back and all screws on each side of the device.
  7. HP iPAQ H2200 Joypad Replacement: Schritt 7, Bild 1 von 2 HP iPAQ H2200 Joypad Replacement: Schritt 7, Bild 2 von 2
    • Remove the back faceplate by pushing and loosening the 4 side slots (2 on each side).
  8. HP iPAQ H2200 Joypad Replacement: Schritt 8, Bild 1 von 1
    • Open the LCD connector, where the orange strip attaches to the main board.
  9. HP iPAQ H2200 Joypad Replacement: Schritt 9, Bild 1 von 1
    • Carefully remove the orange LCD strip from the connector.
  10. HP iPAQ H2200 Joypad Replacement: Schritt 10, Bild 1 von 1
    • Unscrew the 2 screws located at each top corner of the main board.
  11. HP iPAQ H2200 Joypad Replacement: Schritt 11, Bild 1 von 1
    • Remove the main board by pushing outward on the two tabs located on each side near the bottom of the device.
  12. HP iPAQ H2200 Joypad Replacement, Joypad: Schritt 12, Bild 1 von 1
    • Press on the four joypad tabs on the back, and push it through and out the front.
  13. HP iPAQ H2200 Joypad Replacement: Schritt 13, Bild 1 von 1
    • Push the new joypad through the hole; the tabs will lock it into place.
Abschluss
Tyler Andrews
209 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 4-12, Forte Winter 2010 Mitglied von Cal Poly, Team 4-12, Forte Winter 2010
CPSU-FORTE-W10S4G12
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 8
Insgesamt: 3,043
