Zum Hauptinhalt wechseln
LG VX5200 LCD Screen Replacement
Was du brauchst
  1. LG VX5200 LCD Screen Replacement, Battery: Schritt 1, Bild 1 von 2 LG VX5200 LCD Screen Replacement, Battery: Schritt 1, Bild 2 von 2
    • Turn the phone on its back.
  2. LG VX5200 LCD Screen Replacement: Schritt 2, Bild 1 von 2 LG VX5200 LCD Screen Replacement: Schritt 2, Bild 2 von 2
    • Orient the phone as shown.
    • Remove the battery cover by pushing upward with your thumb.
  3. LG VX5200 LCD Screen Replacement: Schritt 3, Bild 1 von 2 LG VX5200 LCD Screen Replacement: Schritt 3, Bild 2 von 2
    • Place your fingernail at the top of the battery and pry the battery out towards you.
  4. LG VX5200 LCD Screen Replacement, Face Plate: Schritt 4, Bild 1 von 3 LG VX5200 LCD Screen Replacement, Face Plate: Schritt 4, Bild 2 von 3 LG VX5200 LCD Screen Replacement, Face Plate: Schritt 4, Bild 3 von 3
    • Flip the phone open.
    • Remove the four rubber plugs, located at the corners of the LCD screen, with a push-pin.
    • Use a Phillips #00 screwdriver to remove the four screws located underneath the rubber plugs.
  5. LG VX5200 LCD Screen Replacement: Schritt 5, Bild 1 von 3 LG VX5200 LCD Screen Replacement: Schritt 5, Bild 2 von 3 LG VX5200 LCD Screen Replacement: Schritt 5, Bild 3 von 3
    • Insert the opening tool in the seam of the top portion of the flip phone.
    • Gently pry the seam open.
    • Move the opening tool around the perimeter of the seam and gently take the front LCD face plate out.
  6. LG VX5200 LCD Screen Replacement: Schritt 6, Bild 1 von 3 LG VX5200 LCD Screen Replacement: Schritt 6, Bild 2 von 3 LG VX5200 LCD Screen Replacement: Schritt 6, Bild 3 von 3
    • Close the flip phone.
    • Hold the base of the phone and gently remove the faceplate.
    • Place the phone and the faceplate on a clean, flat surface.
  7. LG VX5200 LCD Screen Replacement, LCD Screen: Schritt 7, Bild 1 von 2 LG VX5200 LCD Screen Replacement, LCD Screen: Schritt 7, Bild 2 von 2
    • Try not to move the thin component wires as they will bend and break very easily.
  8. LG VX5200 LCD Screen Replacement: Schritt 8, Bild 1 von 3 LG VX5200 LCD Screen Replacement: Schritt 8, Bild 2 von 3 LG VX5200 LCD Screen Replacement: Schritt 8, Bild 3 von 3
    • Remove the white stopper from the camera light located above the gold connector.
    • Lift the gold connector up with your finger to detach it.
  9. LG VX5200 LCD Screen Replacement: Schritt 9, Bild 1 von 1
    • Gently lift out the speaker with your fingertip.
  10. LG VX5200 LCD Screen Replacement: Schritt 10, Bild 1 von 3 LG VX5200 LCD Screen Replacement: Schritt 10, Bild 2 von 3 LG VX5200 LCD Screen Replacement: Schritt 10, Bild 3 von 3
    • Gently lift out the square LCD assembly being careful with the attached vibrator wires.
    • Gently remove the vibrator with tweezers.
    • The LCD screen, speaker and vibrator will separate from the phone as a single unit.
  11. LG VX5200 LCD Screen Replacement: Schritt 11, Bild 1 von 2 LG VX5200 LCD Screen Replacement: Schritt 11, Bild 2 von 2
    • Place phone body and LCD screen on a clean, lint-free surface.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team 4-13, Forte Winter 2010 Mitglied von Cal Poly, Team 4-13, Forte Winter 2010
CPSU-FORTE-W10S4G13
5 Mitglieder
15 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 3
Insgesamt: 3,841
