Einleitung
Once you've extracted the motherboard, replacing the cooling fan only entails removing a few screws.
Was du brauchst
Unlock the tab located in the top left corner of the netbook.
The red tab indicated that the battery has been properly unlocked.
Remove the battery.
Remove six (6) 5mm screws, two (2) 17.5mm screws, and three (3) 2.5mm screws from the back, using the Phillips #0 screwdriver, as marked here.
Pry up the keyboard using a spudger or plastic opening tool in the exact location shown in the photograph.
Carefully disconnect the keyboard ribbon cable from the motherboard, and remove the keyboard.
Separate the upper cover from the back cover. It is possible to do this without a tool, but you may also use a plastic opening tool for added leverage.
Be careful to keep even pressure all the way around the cover so that it is not bent beyond repair.
Carefully disconnect two ribbon cables to complete the separation of the upper cover.
The WiFi card is shown here.
Remove the one (1) 5mm screw holding the card to the motherboard using a Phillips #0 screwdriver.
Disconnect the wires on the WiFi card. This can be done easily by applying pressure to the connections until they pop off of the card.
Using a Phillips #00 screwdriver, remove the four (4) 5mm screws holding the motherboard in place.
Using the #00 Phillips head screwdriver, remove all four (4) screws marked here.
Gently disconnect the fan cable from the motherboard by pulling on the connection until it slips out.
The fan should then be fully disconnected from the motherboard and ready for replacement.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
