Zum Hauptinhalt wechseln
Nintendo DS Lite Lower Screen Replacement
Was du brauchst
  1. Nintendo DS Lite Lower Screen Replacement, Nintendo DS Lite Battery Disconnect: Schritt 1, Bild 1 von 1
    • Place your device upside down and locate the battery compartment.
    • Find the Phillips head screw securing the battery cover in the bottom right hand corner of the device.
    • Loosen the screw enough to remove the battery cover but leave the screw in the cover for reassembly.
    • Use only a Phillips screwdriver to remove screw.
  2. Nintendo DS Lite Lower Screen Replacement: Schritt 2, Bild 1 von 1
    • Slowly remove the battery cover with the iFixit opening tool.
    • Make sure to remove the cover carefully to keep from losing Phillips screw in the cover. It will be needed for reassembly.
  3. Nintendo DS Lite Lower Screen Replacement: Schritt 3, Bild 1 von 2 Nintendo DS Lite Lower Screen Replacement: Schritt 3, Bild 2 von 2
    • Use the iFixit opening tool to carefully pry the battery out of the case.
    • After the old battery is removed replace it with a new battery facing the same direction as when the cover was opened.
    • For some devices, you may be able to remove the battery by flipping the DS over and letting the battery fall into your hand.
  4. Nintendo DS Lite Lower Screen Replacement, Disassembling Nintendo DS Lite Bottom Case: Schritt 4, Bild 1 von 1
    • Remove the following seven screws that secure the lower case to the DS Lite:
    • Three silver tri-wing screws (5mm long)
    • One black tri-wing screw (4mm)
    • Two gold Phillips screws (4mm)
    • One silver Phillips screw (3mm)
    • Do not remove the silver PH screw (3mm) in the battery compartment yet. It holds the main PCB in place.
  5. Nintendo DS Lite Lower Screen Replacement: Schritt 5, Bild 1 von 1
    • On the front edge of the Nintendo DS between the headphone jack plug and volume controls remove the plastic insert (or cartridge) from the lower slot (Slot 2).
  6. Nintendo DS Lite Lower Screen Replacement: Schritt 6, Bild 1 von 2 Nintendo DS Lite Lower Screen Replacement: Schritt 6, Bild 2 von 2
    • Flip the unit over so that it is facing right-side up.
    • Use a spudger to pry open the gap between the bottom case and the front panel. Work all the way around the case until the panel is free.
    • Avoid touching the L and R shoulder buttons, because they easily detach and are difficult to reassemble. Keep the bottom case flat against your workbench to help hold the shoulder buttons in place.
  7. Nintendo DS Lite Lower Screen Replacement: Schritt 7, Bild 1 von 3 Nintendo DS Lite Lower Screen Replacement: Schritt 7, Bild 2 von 3 Nintendo DS Lite Lower Screen Replacement: Schritt 7, Bild 3 von 3
    • Carefully separate the two pieces by hand.
    • The two shoulder buttons are made up of three pieces -- the plastic button, a pin, and a spring. If they accidentally pop out while you are working, study the picture and make sure you put the spring in the correct position.
    • When reassembling the cover, make sure that the power switch caver on the bottom case is in the off (down) position to avoid breakage.
  8. Nintendo DS Lite Lower Screen Replacement, Lower Screen: Schritt 8, Bild 1 von 1
    • Remove the two screws holding the motherboard to the rest of the device using a Phillips #00 screwdriver.
  9. Nintendo DS Lite Lower Screen Replacement: Schritt 9, Bild 1 von 2 Nintendo DS Lite Lower Screen Replacement: Schritt 9, Bild 2 von 2
    • Locate the small ribbon cable that connects the touch screen to the motherboard. Do not pull on this cable.
    • Gently lift the hinged black cover on the connector.
    • The hinges are near where the ribbon is inserted.
    • After lifting the black cover, the ribbon cable will disconnect easily.
  10. Nintendo DS Lite Lower Screen Replacement: Schritt 10, Bild 1 von 1
    • With a plastic opening tool, gently begin to separate the motherboard from the rest of the device.
    • The ribbon cable and two wires are still connected to the motherboard and the buttons tend to fall out.
  11. Nintendo DS Lite Lower Screen Replacement: Schritt 11, Bild 1 von 2 Nintendo DS Lite Lower Screen Replacement: Schritt 11, Bild 2 von 2
    • Flip the motherboard over so the touch screen is facing up.
  12. Nintendo DS Lite Lower Screen Replacement: Schritt 12, Bild 1 von 1
    • Do not pull on the main ribbon cable.
    • Carefully lift the tiny hinged cover on the connector.
    • The ribbon cable will easily disconnect.
    • Remove the third ribbon cable the same way.
  13. Nintendo DS Lite Lower Screen Replacement: Schritt 13, Bild 1 von 1
    • There is nothing else connecting the touch screen. Just pick up and set aside.
Ziellinie
6 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team 16-30, Maness Winter 2010 Mitglied von Cal Poly, Team 16-30, Maness Winter 2010
CPSU-MANESS-W10S16G30
4 Mitglieder
24 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 18
Letzte 7 Tage: 105
Letzte 30 Tage: 334
Insgesamt: 15,583
