Zum Hauptinhalt wechseln
Rival Mini Chopper MC-67BL Turning Gears Replacement
Was du brauchst
  1. Rival Mini Chopper MC-67BL Turning Gears Replacement, Turning Gears: Schritt 1, Bild 1 von 2 Rival Mini Chopper MC-67BL Turning Gears Replacement, Turning Gears: Schritt 1, Bild 2 von 2
    • Twist the plastic lid counterclockwise to unlock it.
    • Lift the lid to remove it from the container.
  2. Rival Mini Chopper MC-67BL Turning Gears Replacement: Schritt 2, Bild 1 von 1
    • Carefully remove the blade from the container.
    • For reassembly, the teeth on the metal shaft line up with slots on the inside of the plastic hole.
  3. Rival Mini Chopper MC-67BL Turning Gears Replacement: Schritt 3, Bild 1 von 1
    • With your hand, twist the container counter-clockwise until it unlocks from the base. Remove the container by lifting it straight up.
  4. Rival Mini Chopper MC-67BL Turning Gears Replacement: Schritt 4, Bild 1 von 1
    • Use your fingers to pry out the two rubber feet from the bottom cover of the base.
    • The two feet furthest from the button tower contain screws. The other two feet do not.
  5. Rival Mini Chopper MC-67BL Turning Gears Replacement: Schritt 5, Bild 1 von 2 Rival Mini Chopper MC-67BL Turning Gears Replacement: Schritt 5, Bild 2 von 2
    • Use the Phillips #2 screwdriver to unscrew the two 12.7-mm screws underneath the rubber feet.
    • Use the same screwdriver to unscrew the 15.88-mm screw from the back of the chopper.
  6. Rival Mini Chopper MC-67BL Turning Gears Replacement: Schritt 6, Bild 1 von 1
    • Firmly lift the bottom cover off of the base.
  7. Rival Mini Chopper MC-67BL Turning Gears Replacement: Schritt 7, Bild 1 von 1
    • Remove the smaller white gear by lifting it up with your hand.
  8. Rival Mini Chopper MC-67BL Turning Gears Replacement: Schritt 8, Bild 1 von 3 Rival Mini Chopper MC-67BL Turning Gears Replacement: Schritt 8, Bild 2 von 3 Rival Mini Chopper MC-67BL Turning Gears Replacement: Schritt 8, Bild 3 von 3
    • Use a pair of pliers or any other clamping tool to securely hold the blade-shaft that sits above the base.
    • Grab the gear with your other hand and turn CLOCKWISE. Unlike most screws, the gear is reverse-threaded to allow the blade to spin.
    • Continue turning the gear until completely removed from the blade-shaft.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Roxanne
522 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 4-29, Amido Fall 2013 Mitglied von Cal Poly, Team 4-29, Amido Fall 2013
CPSU-AMIDO-F13S4G29
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 10
Letzte 30 Tage: 13
Insgesamt: 815
