Zum Hauptinhalt wechseln
LG VX5200 motherboard replacement
Was du brauchst
  1. LG VX5200 motherboard replacement, Battery: Schritt 1, Bild 1 von 2 LG VX5200 motherboard replacement, Battery: Schritt 1, Bild 2 von 2
    • Turn the phone on its back.
  2. LG VX5200 motherboard replacement: Schritt 2, Bild 1 von 2 LG VX5200 motherboard replacement: Schritt 2, Bild 2 von 2
    • Orient the phone as shown.
    • Remove the battery cover by pushing upward with your thumb.
  3. LG VX5200 motherboard replacement: Schritt 3, Bild 1 von 2 LG VX5200 motherboard replacement: Schritt 3, Bild 2 von 2
    • Place your fingernail at the top of the battery and pry the battery out towards you.
  4. LG VX5200 motherboard replacement, LG VX5200 Rear Body Panel Disassembly: Schritt 4, Bild 1 von 1
    • Orient the phone as shown with the battery already removed.
  5. LG VX5200 motherboard replacement: Schritt 5, Bild 1 von 3 LG VX5200 motherboard replacement: Schritt 5, Bild 2 von 3 LG VX5200 motherboard replacement: Schritt 5, Bild 3 von 3
    • Remove the 2 plastic plugs located on the side and upper quadrant of the rear body panel by using the push-pin and lifting outwards.
    • Use a Phillips #00 screwdriver to remove the 5 screws as shown here.
  6. LG VX5200 motherboard replacement: Schritt 6, Bild 1 von 3 LG VX5200 motherboard replacement: Schritt 6, Bild 2 von 3 LG VX5200 motherboard replacement: Schritt 6, Bild 3 von 3
    • Place an iPod opener tool in the seam above the antenna.
    • Run the tool around the perimeter of the entire phone.
  7. LG VX5200 motherboard replacement: Schritt 7, Bild 1 von 1
    • Check to see that your device looks like the attached photo.
  8. LG VX5200 motherboard replacement, main board: Schritt 8, Bild 1 von 3 LG VX5200 motherboard replacement, main board: Schritt 8, Bild 2 von 3 LG VX5200 motherboard replacement, main board: Schritt 8, Bild 3 von 3
    • Locate the tabs that hold the logic board in place.
    • Pull the outer frame of the phone outwards to release the board from the tabs.
  9. LG VX5200 motherboard replacement: Schritt 9, Bild 1 von 3 LG VX5200 motherboard replacement: Schritt 9, Bild 2 von 3 LG VX5200 motherboard replacement: Schritt 9, Bild 3 von 3
    • Locate the copper connection (orange-colored) on the back of the board.
    • Pry the connector free from the board with your fingernail.
  10. LG VX5200 motherboard replacement: Schritt 10, Bild 1 von 1
    • Check to see that your device looks like the image shown.
    • Note: The image is shown with the LCD screen removed. This is not necessary for logic board removal.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team 4-13, Forte Winter 2010 Mitglied von Cal Poly, Team 4-13, Forte Winter 2010
CPSU-FORTE-W10S4G13
5 Mitglieder
15 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 5
Insgesamt: 2,709
