Was du brauchst
Turn Smart Strip upside down and locate four screw holes in corners
Unscrew four corner screws with #0 Phillips Screwdriver
Locate four latch slots in case
Use 2.4mm Slotted Screwdriver, put tip into center of slot, with tip on outer edge of slot, and press inward
Locate latch securing power plugs to bottom of case
Using slotted 2.4mm screwdriver, pry latch away from power plugs to loosen power plugs
2 Kommentare
This is great! Thanks so much!
that awesome and i like how it fix
