Zum Hauptinhalt wechseln
Rival Mini Chopper MC-67BL Safety Latch Replacement
Was du brauchst
  1. Rival Mini Chopper MC-67BL Safety Latch Replacement, Turning Gears: Schritt 1, Bild 1 von 2 Rival Mini Chopper MC-67BL Safety Latch Replacement, Turning Gears: Schritt 1, Bild 2 von 2
    • Twist the plastic lid counterclockwise to unlock it.
    • Lift the lid to remove it from the container.
  2. Rival Mini Chopper MC-67BL Safety Latch Replacement: Schritt 2, Bild 1 von 1
    • Carefully remove the blade from the container.
    • For reassembly, the teeth on the metal shaft line up with slots on the inside of the plastic hole.
  3. Rival Mini Chopper MC-67BL Safety Latch Replacement: Schritt 3, Bild 1 von 1
    • With your hand, twist the container counter-clockwise until it unlocks from the base. Remove the container by lifting it straight up.
  4. Rival Mini Chopper MC-67BL Safety Latch Replacement: Schritt 4, Bild 1 von 1
    • Use your fingers to pry out the two rubber feet from the bottom cover of the base.
    • The two feet furthest from the button tower contain screws. The other two feet do not.
  5. Rival Mini Chopper MC-67BL Safety Latch Replacement: Schritt 5, Bild 1 von 2 Rival Mini Chopper MC-67BL Safety Latch Replacement: Schritt 5, Bild 2 von 2
    • Use the Phillips #2 screwdriver to unscrew the two 12.7-mm screws underneath the rubber feet.
    • Use the same screwdriver to unscrew the 15.88-mm screw from the back of the chopper.
  6. Rival Mini Chopper MC-67BL Safety Latch Replacement: Schritt 6, Bild 1 von 1
    • Firmly lift the bottom cover off of the base.
  7. Rival Mini Chopper MC-67BL Safety Latch Replacement: Schritt 7, Bild 1 von 1
    • Remove the smaller white gear by lifting it up with your hand.
  8. Rival Mini Chopper MC-67BL Safety Latch Replacement: Schritt 8, Bild 1 von 3 Rival Mini Chopper MC-67BL Safety Latch Replacement: Schritt 8, Bild 2 von 3 Rival Mini Chopper MC-67BL Safety Latch Replacement: Schritt 8, Bild 3 von 3
    • Use a pair of pliers or any other clamping tool to securely hold the blade-shaft that sits above the base.
    • Grab the gear with your other hand and turn CLOCKWISE. Unlike most screws, the gear is reverse-threaded to allow the blade to spin.
    • Continue turning the gear until completely removed from the blade-shaft.
  9. Rival Mini Chopper MC-67BL Safety Latch Replacement, Power Button: Schritt 9, Bild 1 von 1
    • Use your hand to firmly pull the blade-shaft from the base.
  10. Rival Mini Chopper MC-67BL Safety Latch Replacement: Schritt 10, Bild 1 von 1
    • Using Phillips #2 screwdriver, unscrew two 12.7-mm screws in the middle of the base.
  11. Rival Mini Chopper MC-67BL Safety Latch Replacement: Schritt 11, Bild 1 von 1
    • Unwind power cord from the base pegs.
  12. Rival Mini Chopper MC-67BL Safety Latch Replacement: Schritt 12, Bild 1 von 2 Rival Mini Chopper MC-67BL Safety Latch Replacement: Schritt 12, Bild 2 von 2
    • Use the plastic opening tool to pry open the base from the main body.
    • These two plastic prongs are pressed fit into the base. It may take some effort to pry the base completely off.
    • Once freed, lift the base panel from the main body and set it aside.
  13. Rival Mini Chopper MC-67BL Safety Latch Replacement: Schritt 13, Bild 1 von 2 Rival Mini Chopper MC-67BL Safety Latch Replacement: Schritt 13, Bild 2 von 2
    • Use a Phillips #2 screwdriver to remove the three 9.53-mm screws from inside the main body.
    • Next, turn the device upright and lift the upper casing from around the button gently.
  14. Rival Mini Chopper MC-67BL Safety Latch Replacement: Schritt 14, Bild 1 von 1
    • Remove the button by simply pulling it up.
    • Don't lose the spring under the button! Without it, the blender will not function.
  15. Rival Mini Chopper MC-67BL Safety Latch Replacement, Safety Latch: Schritt 15, Bild 1 von 1
    • Use the Phillips #2 screwdriver to remove one 9.53-mm screw.
  16. Rival Mini Chopper MC-67BL Safety Latch Replacement: Schritt 16, Bild 1 von 1
    • Remove the white latch by unhooking it from the spring wire and gently lifting straight up.
Abschluss
Roxanne
522 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 4-29, Amido Fall 2013 Mitglied von Cal Poly, Team 4-29, Amido Fall 2013
CPSU-AMIDO-F13S4G29
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 10
Letzte 30 Tage: 13
Insgesamt: 1,454
